Server Version#: 1.27.2.5929 (QNAP X86)
Player Version#: 1.48.2.3124-647ff031 (MacBook Air (M1, 2020))
This question has been around for a while, opening the lyrics shows “Error loading lyrics”
I’m not able to reproduce this. Can you try refreshing the album, then try playing the file again? Get me the server logs if you get the same failure.
Sorry for replying a few days late.
Following your instructions, I refreshed the album metadata, but the problem remains. Test time: July 21, 17:33 Beijing time
Plex Media Server Logs_2022-07-21_17-35-12.zip (1.8 MB)
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="18" librarySectionTitle="音乐" librarySectionUUID="7631a354-0947-4ee6-8da9-64aff3e9e6d0" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1657719163">
<Track ratingKey="88433" key="/library/metadata/88433" parentRatingKey="88430" grandparentRatingKey="88033" guid="plex://track/5dc0a804115974d9a2e7e92c" parentGuid="plex://album/5db6e132b37302b855b6d713" grandparentGuid="plex://artist/5d07bbfc403c6402904a5cdb" type="track" title="Falling In Love Again" grandparentKey="/library/metadata/88033" parentKey="/library/metadata/88430" librarySectionTitle="音乐" librarySectionID="18" librarySectionKey="/library/sections/18" grandparentTitle="席琳·迪翁 (Celine Dion)" parentTitle="Courage (Deluxe Edition)" originalTitle="Céline Dion" summary="" index="3" parentIndex="1" ratingCount="7900" userRating="10.0" viewCount="6" lastViewedAt="1658396078" lastRatedAt="1657424617" parentYear="2019" thumb="/library/metadata/88430/thumb/1655327217" art="/library/metadata/88033/art/1658001681" parentThumb="/library/metadata/88430/thumb/1655327217" grandparentThumb="/library/metadata/88033/thumb/1658001681" grandparentArt="/library/metadata/88033/art/1658001681" duration="231363" addedAt="1651990954" updatedAt="1658001690" musicAnalysisVersion="1">
<Media id="91554" duration="231363" bitrate="1521" audioChannels="2" audioCodec="flac" container="flac">
<Part accessible="1" exists="1" id="135253" key="/library/parts/135253/1651990683/file.flac" duration="231363" file="/share/CACHEDEV5_DATA/Music/s4j4_Music/席琳·迪翁 (Celine Dion)/Courage (Deluxe Edition)/03 - Falling In Love Again.flac" size="44315962" container="flac" deepAnalysisVersion="6" requiredBandwidths="1523,1523,1523,1523,1523,1523,1523,1523">
<Stream id="179220" streamType="2" selected="1" codec="flac" index="0" channels="2" bitrate="1521" albumGain="-10.97" albumPeak="1.000000" albumRange="10.766572" audioChannelLayout="stereo" bitDepth="24" endRamp="-51.00 0.16;-39.82 6.46;-29.97 8.56;-23.36 9.46;-20.26 9.76;-16.93 9.96;-12.98 10.16;-10.87 10.26;-8.60 10.36;-5.56 10.56;-2.63 11.16;0.82 12.96;3.27 13.46;6.48 38.16;" gain="-10.97" loudness="-12.21" lra="10.82" peak="1.000000" requiredBandwidths="1523,1523,1523,1523,1523,1523,1523,1523" samplingRate="44100" startRamp="-51.00 0.00;-18.72 0.20;-13.98 0.30;-11.06 0.50;-8.79 1.70;-5.30 7.30;-1.17 13.60;2.09 13.70;5.21 13.80;7.66 13.90;" displayTitle="FLAC (Stereo)" extendedDisplayTitle="FLAC (Stereo)"></Stream>
<Stream id="185620" key="/library/streams/185620" streamType="4" codec="lrc" format="lrc" minLines="3" provider="com.plexapp.agents.lyricfind" timed="1" displayTitle="LRC (外部)" extendedDisplayTitle="LRC (外部)"></Stream>
</Part>
</Media>
<Guid id="mbid://feb5f5c8-4af2-45d2-a33a-80847023edcf"/>
<Extras size="0"></Extras>
<Related></Related>
</Track>
</MediaContainer>
Everything looks fine. Can you try in other Plex clients and see if you get the same. It may be a specific problem to the Plex for Mac app.
Excuse me, is there any progress? Thank you
I’ve been trying to recreate this but I can’t. Can you enable logging in the Web client, reproduce the error, then grab the logs and send those to me.
The time when the problem occurred: Beijing time, July 26, 07:20-07:21
Plex web log.txt.zip (15.5 KB)
The logs say that the lyrics could not be retrieved from LyricFind. Keep in mind that we don’t store the Lyrics, just the link to them. Has this worked for you in the past?
Before, when the lyrics button was displayed on the playback interface, the lyrics could definitely be displayed.
Now, when the lyrics button is displayed on the playback interface, most of the lyrics cannot be displayed, but there are still a few that can display the lyrics.
If the inability to retrieve lyrics from LyricFind is caused by network problems, the playback interface should not display the lyrics button, and some music can retrieve and display lyrics from LyricFind, indicating that the possibility of network problems is relatively small.
Can you Plex Dance that Celine Dion album? If it still doesn’t work, get me a new log.
For comparison, I conducted two parts of the test: the lyrics can be displayed normally and the lyrics are displayed incorrectly
Plex Web log.txt.zip (199.3 KB)
Did you play something else? Please continue using the Celine Dion song so it’s easer to track. Did you perform the Plex Dance as requested for that album?
Refer to Plex Dance , follow the steps to perform the relevant operations, the problem still exists.
log.zip (967.7 KB)
Ok, so it shows a 404 error (file not found) when it is looking for the lyric file. So PMS thinks there is a lyric but it can’t find it. That’s causing the error. Let me try creating a test album with that song and see if I can reproduce the problem. It could be an issue that LyricFind has a bad file on their end.
Actually looking more at your logs. LyricFind didn’t even run to find lyrics. Are you using embedded lyrics in your files? Can you PM those 2 tracks so I can try.
I tried creating a test album and it shows it found 0 matching lyrics. It is very common for LyricFind to not have lyrics for other versions of an album other than the original, so it not finding lyrics for the Deluxe Edition is not unusual.
Test file, please help to verify. Thank you
Courage (Deluxe Edition).zip (10.2 MB)
@MovieFan.Plex Hi, according to your requirements, re-test and reproduce the problem
Do you still see the Lyric button? It looks like you still have the album in your regular library, so it may be reusing the old info. We need to clear out that info so it won’t reuse it.
Aug 03, 2022 14:49:38.363 [0x7feb4370fb38] DEBUG - [Req#96] [Notify] Now watching “/share/CACHEDEV5_DATA/Music/s4j4_Music/席琳·迪翁 (Celine Dion)/Courage (Deluxe Edition)”
@anon18523487 Hello, delete the original music album and test again, the problem remains
The test steps are as follows:
The above is performed according to the steps of Plex Dance, the operation time is 19:35-19:37 Beijing time on August 5th
