EPG Data missing with "to be annouced"
Another UK user affected here.
This is should mostly be resolved now. There may be times that you see a “To be announced” in the future but things should get reingested more frequently which a guide refresh should then pick up.
Thank you so much for your efforts and taking notice of this in a timely manner. Appreciate it.
Thank you!
Still happening.
Right now at 11pm I have TBA on CBS and ABC for 11:30pm.
Just tonight I’m seeing TBA on CBS for 11:30PM in 27703. :Looks like it’s TBA for the rest of the week.
@cwoody222 @jpwoodbu which channel numbers are those. Seems to be a couple CBS channels in your zip codes I can’t find the one that has TBA stuff
TBA in 14217:
11:30pm Tues 2/4 ABC/WKBW
12:30pm Tues, Wed, Thurs 2/4-2/6 CBS/WIVB
CBS in 27703 is RF channel 8, program channel is 17.1. I just looked at my program guide again and the TBA’s for the CBS 11:30PM slot look correct now.
@cwoody222 Just wanted to confirm I am looking at the correct thing. You see “News at Noon” at noon, then from 12:30 to 3pm you only see TBA until at 3pm when “Daytime Buffalo” appears? is that correct?
No, I am seeing listings from 12:30-3pm on WIVB.
I’m seeing TBAs during late night, not afternoons.
So you meant 12:30 am here?
Oh yes sorry, typo. I meant AM for CBS.
The program guide for KPIX (CBS) 5.1 in the SF Bay area shows “To be announced” for most of the programs between 8pm and 2am. 80% of my DVR recordings are on that channel, and fall within those times. As a result, DVR recordings are simply not happening.
The guide seems to be accurate for times other than 8pm - 2am, as well as for other channels.
@cwoody222 I see Stephen Colbert then someting called AfterMignight at 12:37am. If you have not can you try manually refreshing epg
It does look like there are two channel 4.1 listed for your area code. can you check the DVR settings and make sure the right one is mapped.
@madbrain what is your postal code?
95127 .
After midnight is also one of the shows I’m most frequently missing. For example, last night. It’s niche enough that it’s not even on torrents yet. Unlike a second program that also didn’t record last night, NCIS origins.
I tried a manual refresh, still not seeing After Midnight.
I did have the right 4.1. I tried to switch to the other to be sure.
I see it in the EPG i am looking at for your postal. stating at 12:37 tonight. You are using OTA right? the guests tonight are “Melissa Rauch; Jessica St. Clair; Nico Santos” looks correct.
OK thanks for trying.
I think will need to speak with one our devs to see what else may be needed to look into this. but probably will need your server logs to start. Guessing some old data is cached somewhere.
