Server Version#: Version 1.20.5.3562
Player Version#: Version 4.43.4
I’ve run into an issue where some, but not all, episode names for The Twilight Zone (1980’s) appear to show some kind of disc metadata, rather than the episode name. I’ve attached a screenshot where the episode name on the left shows up correctly, but the one on the right doesn’t. That being said, when I click into the incorrectly named episode, it shows the correct episode metadata, just not the title.
Is your file for that episode an MP4 or M4V?
I don’t think the naming in a problem in this case as the only place I can imagine a episode title like “Twilight Disc 2” could come from is embedded metadata in an mp4/m4v
if so then move Local Media Assets (TV) below TVDB in agent settings
This did the trick! I reordered the agents, unmatched the series, rematched, and all of the episodes were applied correctly. Thank you so much!
I’ll read more about how the Plex agents work. Thanks again!
