Server Version#:1.21.0.3711-b0509cc236
Player Version#:4.48.1
I know that this has happened many times before but could not find anything that helped. My media is on a NAS (ext4) running nfs which played just fine just after loading 1 season. The NAS is the same as below with a WD Green 1TB SSD. Because of changes in labeling I reloaded all video and the error is in the topic. I mount the shared server (NAS) just fine and see all of the content on the mount point with the data sources created from them
The server is running on a RPi 4 with 4GB buster version 10.
I thought ‘Web Optimized’ was the answer but not so lucky. I am using MacX DVD Ripper Pro and I tried both mp4 and mkv with mkv I ran through HandBrake both with ‘Web Optimized’ and not. The odd thing is that some which were working before are not now.
I am running my NAS and Plex servers on Pi4 4 GB using NFS and all connections seem to be working there. My client is a Mac
For some reason I think that the new version of plex server is not coming through otherwise I may expect to have different scanning and a different result.
Help please, there is nothing else I think I can try. I have seen a write up on
Download is fine and is not slow. note that all data is on SSD.
As far as codecs I don’t know how to do that and if I wipe out that on the working episodes that would not seem great since that may result in none of them working. The fact that I am not seeing the selection on Agent/Scanner would seem to not be fixed.
If you think that is the answer I am willing to try anything.
I honestly figure that is it. I communicated with someone else on the same type of problem and he said that the new scanner fixed it for him. For some reason the version went from 1.21.1.3850 to 1.21.1.3830 recently.
Hi ajwtech. I was glad to see someone from Plex looking at this. Could you please jump in again? I must be missing something. Just note that the shows failing have XML similar to the following
I have downloaded the version and now see the Plex TV Series selection for Scanner and agent. This really didn’t do me any good. Since then I got FileBot (as suggested by Trumpy) and can now see Mad About You and Seasons 4-5 of Home Improvement. Unfortunately I overlaid Seasons 1-3 and the FileBot names do not work.
For Friends and Seinfeld I can’t find any naming convention that works
Notice the .py line number in update, agent_get_version and sandbox.py also KeyError: ‘plex’. It appears that a couple of the Python routines have errors. Please let me know when these are fixed so that I can download a new release.
And the XML indicates missing a whole lot of part data
All of my permissions on the directories (owner root) are 777 and on the files 355 (owner root). Should I change the owner? It doesn’t seem to make sense since the permissions for user are R/W/X.
Hey there, time for some direction. I can’t think of anything else.
