Sep 07, 2016 02:46:15.818 [0xecfffb90] DEBUG - Butler: Scheduling deep analysis for: La carica dei 101
Sep 07, 2016 02:46:15.818 [0xecfffb90] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/6209f91-1114-linux-debian-i686/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' '--analyze-deeply' '--item' '587' '--log-file-suffix' ' Deep Analysis'
Sep 07, 2016 02:48:30.767 [0xecfffb90] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/6209f91-1114-linux-debian-i686/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' '--generate' '--chapter-thumbs-only' '--item' '547' '--log-file-suffix' ' Chapter Thumbnails' '--force'
Sep 07, 2016 02:51:17.114 [0xecfffb90] DEBUG - Jobs: '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' exit code is 0
Sep 07, 2016 02:51:17.360 [0xecfffb90] DEBUG - Updating metadata item (save) (Ep 04 Oathkeeper in Cerca Di Un Colpevole) with ID 547
Sep 07, 2016 02:51:17.669 [0xecfffb90] DEBUG - AutoUpdate: requesting check endpoint: /updater/products/1/check.xml?build=linux-debian-i686&channel=16&distribution=qnap&version=1.1.3.2700-6f64a8d, download: YES
Sep 07, 2016 02:51:17.688 [0xecfffb90] DEBUG - Downloading document https://plex.tv/updater/products/1/check.xml?build=linux-debian-i686&channel=16&distribution=qnap&version=1.1.3.2700-6f64a8d
Sep 07, 2016 02:51:17.750 [0xecfffb90] DEBUG - HTTP requesting GET https://plex.tv/updater/products/1/check.xml?build=linux-debian-i686&channel=16&distribution=qnap&version=1.1.3.2700-6f64a8d
Sep 07, 2016 02:51:19.628 [0xecfffb90] DEBUG - HTTP 200 response from GET https://plex.tv/updater/products/1/check.xml?build=linux-debian-i686&channel=16&distribution=qnap&version=1.1.3.2700-6f64a8d
Sep 07, 2016 02:51:19.747 [0xecfffb90] INFO - AutoUpdate: no updates available
Sep 07, 2016 02:51:19.748 [0xecfffb90] DEBUG - Butler: Scheduling deep analysis for: Pirates of the Caribbean: On Stranger Tides
Sep 07, 2016 02:51:19.748 [0xecfffb90] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/6209f91-1114-linux-debian-i686/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' '--analyze-deeply' '--item' '615' '--log-file-suffix' ' Deep Analysis'
Sep 07, 2016 02:53:29.518 [0xecfffb90] DEBUG - Butler: Scheduling deep analysis for: The Aristocats
Sep 07, 2016 02:53:29.519 [0xecfffb90] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/6209f91-1114-linux-debian-i686/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' '--analyze-deeply' '--item' '589' '--log-file-suffix' ' Deep Analysis'
Sep 07, 2016 02:56:04.888 [0xecfffb90] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/6209f91-1114-linux-debian-i686/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' '--generate' '--chapter-thumbs-only' '--item' '546' '--log-file-suffix' ' Chapter Thumbnails' '--force'
Sep 07, 2016 02:58:21.962 [0xecfffb90] DEBUG - Jobs: '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' exit code is 0
Sep 07, 2016 02:58:22.225 [0xecfffb90] DEBUG - Updating metadata item (save) (Ep 03 Breaker of Chains La Fuga) with ID 546
Sep 07, 2016 02:58:22.685 [0xecfffb90] DEBUG - Butler: Scheduling deep analysis for: X-Men - Giorni di un futuro passato
Sep 07, 2016 02:58:22.685 [0xecfffb90] DEBUG - Job running: FFMPEG_EXTERNAL_LIBS='/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex\ Media\ Server/Codecs/6209f91-1114-linux-debian-i686/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/share/CE_CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Media Scanner' '--analyze-deeply' '--item' '573' '--log-file-suffix' ' Deep Analysis'
Sep 07, 2016 03:00:10.186 [0xf3de2740] DEBUG - Shutting down with signal 15
Sep 07, 2016 03:00:11.264 [0xf3de2740] DEBUG - Ordered to stop server.
Sep 07, 2016 03:00:17.009 [0xf3de2740] WARN - Timed out waiting for server to finish.
Sep 07, 2016 03:00:17.872 [0xf3de2740] DEBUG - Stopping server...
Sep 07, 2016 03:00:19.137 [0xeebffb90] DEBUG - TranscodeJobManager: [Running] onServerShutdown
Sep 07, 2016 03:00:20.310 [0xf3de2740] WARN - Timed out waiting for server to finish.
Sep 07, 2016 03:00:20.416 [0xeebffb90] DEBUG - TranscodeJobManager: [Running] -> [Shutdown]
Sep 07, 2016 03:00:21.470 [0xf3de2740] DEBUG - Server stopped.
Sep 07, 2016 03:00:22.604 [0xf3de2740] DEBUG - NetworkService: Stopping advertisement.
Sep 07, 2016 03:00:22.919 [0xf3de2740] DEBUG - Killing plug-ins.
Sep 07, 2016 03:00:22.919 [0xf3de2740] DEBUG - [com.plexapp.agents.movieposterdb] Killing.
Sep 07, 2016 03:00:23.053 [0xf3de2740] DEBUG - [com.plexapp.agents.imdb] Killing.
Sep 07, 2016 03:00:23.053 [0xf3de2740] DEBUG - [com.plexapp.agents.plexmusic] Killing.
Sep 07, 2016 03:00:23.054 [0xf3de2740] DEBUG - [com.plexapp.system] Killing.
Sep 07, 2016 03:00:23.043 [0xf07ffb90] ERROR - Network Service: Error in advertiser handle read: 125 (Operation canceled) socket=65
Sep 07, 2016 03:00:23.124 [0xf3de2740] DEBUG - [com.plexapp.agents.themoviedb] Killing.
Sep 07, 2016 03:00:23.165 [0xf3de2740] DEBUG - Database: Shutting down.
Sep 07, 2016 03:00:23.213 [0xf07ffb90] INFO - Network Service: Abandoning advertise socket, it was closed.
Sep 07, 2016 03:00:26.590 [0xe7afbb90] DEBUG - Stopping file watcher for com.plexapp.agents.themoviedb
Sep 07, 2016 03:00:27.903 [0xf1623b90] DEBUG - Stopping file watcher for com.plexapp.system
Sep 07, 2016 03:00:28.287 [0xe9e23b90] DEBUG - Stopping file watcher for com.plexapp.agents.plexmusic
Sep 07, 2016 03:00:28.288 [0xe9b35b90] DEBUG - Stopping file watcher for com.plexapp.agents.imdb
Sep 07, 2016 03:00:28.354 [0xea111b90] DEBUG - Stopping file watcher for com.plexapp.agents.movieposterdb
My PMS, hangs with this final log
