Every recording is throwing an error - “an error occurred while post-processing the recording”
However I do not have anything entered in for the postprocesing script - I don’t do any post processing. If this field is blank there should be no post processing and there should be no error thrown. The recordings are being added and watchable, just need this error to go away.
I’m having the very same issue. I do have a post-processing script to run comskip, and I get a post-processing error on every recording. A few recordings have failed to appear in the TV library, but most of them are fine.
Hi this is happening to me too, Is this maybe a freebsd problem, I too has a post process script for comskip, I removed my link to if and still I get this error
Have you ensured that the built-in Comskip has been disabled globally and for all series recordings? IIRC, built-in Comskip doesn’t work yet on FreeBSD, and it was accidentally enabled by default for all series in the first 1.10.0.x release.
