Same for Munich East and probably several (if not all?) others.
Thank you. It appears to have been a change that came in between the 8th and 13th of december - don’t know if all the lineups got affected then
I am referring this to our provider
The main Germany lineup has also the Mainfranken move with no EPG data.
The 103 and 114 RTL channels have now been restored to the lineups. The fix is live in our data now - please refresh the guide / check the channel lineup matching in DVR Setup
I can confirm that in the German-wide Kabel Deutschland lineup, channel 103 is RTL again. EPG update is on running currently.
114 has the wrong logo, it’s using the RTL SD logo from 103 instead of the RTL HD logo.
https://upload.wikimedia.org/wikipedia/commons/e/e1/RTL_HD_Logo.svg
115 SAT.1 HD currently has no logo at all, here is the correct one:
We have come far that now logos are something to worry about
That is good to hear !!!
Well this was kind of a joke but one also has to admit, that things are slowly improving.
At least one can say, that you do your best to iron out the gazillion of flaws that the new guide has. I can confirm that RTL (HD) also works on Kabel Deutschland Munich West.
Missing in the EPG data for the austrian channel ORF1 (ORFEINS), get only “To Be Anounced”
Any chance to get data for this channel?
Which lineup exactly?
Sitting here in Ulm near Munich, DVB-C via Fritzbox 6590 Cable, TV Provider is local municipal services (SWU)
Tried several postcodes and cable providers.
Problem seems for me the epg itself not providing data for ORF1
Der Sender muss halt im Zweifel “von Hand” in eine Lineup eingepflegt werden, deshalb ist wichtig welche die richtige für dich ist. Du befindest dich allerdings im Thread von Kabel Deutschland
Versuch Mal was an der Grenze zu unseren östlichen Nachbarn, da hast du evtl Glück.
Habe bereits mehrere verschiedene ausprobiert, auch Kabel Deutschland Neu-Ulm. ORFONE ist ja auch jedesmal vorhanden und lässt sich mappen, nur scheint das EPG nichts hinterlegt zu haben, da immer nur “to be announced” im EPG erscheint.
War das gleiche mit RTL, da kam auch eine zeitlang die gleiche Meldung und jetzt kommen auf einmal Daten.
Achso, dann muss der Sender “nur” mit Daten gefüttert werden. @sa2000 kann sich darum kümmern, wenn er Notiz davon nimmt.
Schreib nochmal auf englisch PLZ, Lineup Name und genauer Kanal mit Nummer wo die Infos fehlen. Dann wird sich irgendwann drum gekümmert.
OK, Infos in english for @sa2000 :
Missing EPG Data for Channel ORFEINS, actually get only “To be anounced”
PLZ 89231
I would be happy if you could add these.
Mapped EPG Channel 155 to 51:
Thank you for reporting this. The “TBA” data issue for channel 155 ORF Eins has now been reported to our provider - Example of lineup with the issue: Kabel Deutschland Neu-Ulm Digital
Thx for forwarding.
Yes, looks good for me. Epg data is here.
Thank you very much
