Works for München East, RTL HD (#114) is present again. No picon but hey, at least there is some EPG
This was added a few days ago and is now visible in the EPG data - channel 114 on the Kabel Deutschland Germany Digital lineup
Well, thank you.
But the free SD channel ist 103 which is also available. “RTL HD” (114) is a pay tv service to my knowledge.
Both works (haven’t checked it myself), so where exactly is the problem now?
That’s fine.
@Coxeroni no problem, just as an addition to the info (SD/HD) - and info on free/not free in the cable network.
Ok noted
People like me, that only use the HD channels, tend to forget the SD ones.
Rtl, regional, south east germany epg missing and in my list there is no normal rtl to pick instead only the regional ones, and some austrian channels whitch we (not everywhere) in germany can watch are missing completely, like atv, atv2, puls4, orf 3, orf sport.
Lineup, zip code?
If you would name that provider, Plex/@sa2000 could possibly make it available. Without a name, it will be difficult. Is it an independent one or a subsidiary of one of the bigger ones like Pyur for example?
I would also report this via the official form available here:
Thank you for your assistance
It would be good to provide a link to where the complete list of channel numbers and channel names can be found. The only info I can see is transmitter info and UHF frequencies here https://www.komro.net/sites/default/files/downloads/Frequenzliste%20Rosenheim%2C%20Engelsberg%2C%20Penzberg_02_2020.pdf
I will pass a request on anyway
i will talk to the cable provider on monday.
is like -RTL HD = Number 114- a common thing they have to know? then i try to give you all the numbers, with channel names, and all the zip codes they run on.
offtopic
before i used plex live tv and chose my country as austria because the austrian channels are more important to me then miss a few german channels… but for a few days i have a replacement device because the fritz.box was broken and to set it up again with my country picked austria didnt really worked good this time… (channel assignment and missed a lot of channels)
Our epg data provider will need a list provided by the cable company rather than one provided by me or you. So an official web page or if not, a contact point
Lineup Kabel Deutschland München Ost
Zip 81476
Channel 116 Pro Sieben HD - 20.05.2020 20:15 CEST
Tonight’s episode of Grey’s anatomy does not have S/E info, should be S16E03 and have the new indicator. Since it is a new episode a lot of wives will be unhappy if it is missed.
@sa2000 dunno if you will take care of it, haven’t reported anything for a while.
Next week’s episode (27.05.) also lacks S/E info.
Thank you and thanks for the further information
I can confirm that future airings now have S/E info (hopefully correct one).
Thanks for the fix.
Zip 81476
Channel 114 RTL München HDTV - 28.05.2020 20:15 CEST
The Plex Guide shows a wrong programme for 20:15 on. It shows two airings of “Der Lehrer” while in reality it should be " Let’s Dance - Die schönsten Tänze aller Zeiten" (see https://www.rtl.de/fernsehprogramm/). I guess the programme was changed, but I don’t know when.
I know it’s too late to get it corrected, just wanted to let you know @sa2000.
