ETA for Kabel Deutschland regional lineups?
At the moment there are some serious issues with the EPG data and its accuracy after ingestion issues at our provider end. Would need to wait for these to get resolved over next few days and then we can look specific data issues
Ok, thx for the heads up. No need to investigate this specific issue anyways.
We have completed ingestion of the 29th May data and the cache has cleared. Please do a manual refresh of the Guide or wait for the next automatic scheduled task and check for these errors and let me know if they are still there.
A lineup was added recently for your cable provider
Select “Komro Germany Digital” guide/lineup in DVR Setup
Let me know if there are any errors
its working.
thank you very much!
there are only 2 things
no epg data for Puls24 (i have epg data on my tv)
here its called Plus24?
sdfsdfnannt
there is no channel ATV2 (autrian channel)
one other problem is (for long time) that i miss names of episodes from shows. like Terra X
I will refer this back to our provider
Do you know what channel number this is ?
I can see that 227 is ATV Avrupa
what channel number and channel name this is on?
ATV Avrupa is a turkey and not the austrian atv staitions…
this are the stations (that i know of so far…)
documentations where i cant see what its about
here its works
Is all the channel mapping from tuner to EPG with this lineup manual ?
Does the cable provider use channel numbers? or are these assigned by the tuner and may vary from one tuner to another ?
So 227 ATV Avrupa is wrong and does not exist as a channel from your cable provider and it needs to be ATV 2 ?
With regards to season and episode numbers - not all shows are sequenced and some sequencing is just date based. I will put a request in for “Terra X” to be sequenced and see what we get back as a response from our provider
90% of the mapping was right
227 ATV Avrupa exists but is wrong… the provider only gives mhz, no channel numbers
2111annt
my tv is showing me on terra x no short title. the description of what the episode is about is the long text. on plex its always the same just saying “terra x is a dokumentation…”
i think this is a problem on all channels in some casses. i saw some more on different channels.
thanks for your help
Looked into this and we have a limitation currently on how the synopsis text is handled - we are currently not picking up text for episodes where that episode text is different for different channels. In such cases a generic TV Show description is used. It is hoped that this will get addressed in the future.
