Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3 running 5.3
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.0.165
The device and operating system (including version number) that PlexConnect is installed on: Desktop PC, windows 8 pro 64b Intel Core2 1.86Ghz 4GB ram
The local IP address of the device that PlexConnect is installed on: 192.168.0.165
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Qnap TS421 FW: 3.7.1 Build 20120615
The Plex media server (PMS) version number you are running (**do not put 'latest'**): 0.9.7.28.3
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.0.149
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. 23/07/2013 13:19u
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]port_pms = 32400enable_plexgdm = falsip_dnsmaster = 8.8.8.8ip_webserver = 0.0.0.0loglevel = Normalenable_dnsserver = Truelogpath = .ip_pms = 192.168.0.165port_webserver = 80
Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space): Applies to all media files. mainly 720p MKV files
A detailed description of the issue (the clearer you can make this the better): I've been struggling here for the past few days. I'm trying to get Plex working on my ATV but keep running into an error when playing the movie's. "An error has occured while loading this content" (translated from dutch)
I've installed PMS on my Qnap TS421 (unofficial ARM package) and have plexconnect running on a Windows8 pro desktop.I tried to install the Plex media center on another Win8 laptop and everything worked great on there. Moves playback without a hitch. So I don't think anything is wrong with the PMS.
Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one: http://pastebin.com/b3nAG8By
Thank you for taking a look at my issue at hand.
Frank
