Server Version#: Newest version
Player Version#: Newest version!
I don’t know where to ask for help. I tried to figure it out for about a week now. My pc is getting full with copies of all these files. I really hope someone can help me out.
like you can see the file path is good, the name is good. Everyting should be good but plex cant read the file.
They are .part files and a .mkv files
I have this problem with Dragon Ball and Dragon Ball Z Kai season 2 everyting else is working fine. I can’t post a link of a screenshot but i double checked it
I hope someone can help me out!
Btw first post so idk if i posted it on the right spot
A .part file means this is not a completely download or decompressed file. And therefore it is not a video file at all, which Plex can recognise.
Do all these files play in a desktop player, e.g. VLC ?
Agreed, your folder structure is like it should be.
Hoever, I cannot recognise your file names, because they are all clipped. Particularly not the filename extensions.
I hope, you did only add D:\TV Shows to your tv shows library?
Don’t even try to add D:\TV Shows\Dragon Ball directly.
In case that some of your files are mp4/m4v files, do the following:
Go to
- Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
- Settings - Server - Agents - Shows - TheMovieDatabase
- Settings - Server - Agents - Movies - Plex Movie
- Settings - Server - Agents - Movies - TheMovieDatabase
Then perform the Plex Dance with all files of this show.
Yup the first one i tottaly forgot about that, so that is the reason dragonball is not shown in plex. But for dragon ball z kai season 2 that is not the problem. Those files are all .mkv.
Yes i only added D:/TV Shows to my library. Sadly none are mp4. https://prnt.sc/qmnhda its dutch but it says that all files are .mkv.
Sadly it did not work
Have you performed the Plex Dance with those files?
