Failed to Find Consumer error; live TV stops a few minutes after initiating playback (seems to be android tv client related)
Awesome! Glad to help!
Hey all, sorry I did not get around to posting last week
Just to let you know, the latest beta should have fixed the issue :slight_smile: @vishal207 and @Tacorifficdid are you still have issues with the latest beta? If so, any chance you could provide some further logs?
thanks for helping out :bowing_man:
@daioio from my understanding, the problem is in the client player isn’t?
Do you guys know when the update will be pushed on the player of the FireStick?
Is there a way I can download the beta on the FireStick?
Right now, it is not really possible to watch Live TV with the Firestick since there is the circle of death every 5minutes… :frowning:
Thanks!
vdd,
Both the Android and Amazon Fire Stick betas can be downloaded at the below link. The last post at the bottom. You have to have Plex Pass to use them. And you have to side load them.
I installed the one labeled ā€œAmazon AppStore (armv7a)ā€ on my Fire Stick 4k and it has been playing live tv without errors for about an hour now. It looks like the fix worked.
daioio
Thanks for your help. I tried the beta earlier and it fixed the bug on my android mobile device but not on my android tv device (shield). Had to revert back to the version mentioned by tacorrific.
I reinstalled the beta on the shield this morning and same error as before. logs attached.
Error at ~11:32
Nvidia.Shield.Logs-8.7.0.20631-beta.txt (28.6 KB) Plex Media Server.log (1016.2 KB)
I also still have the issue with the latest beta.
I installed the version of Tacorrific and it seems to be working fine!
Sure thing happy to help out daioio! Just tested the new beta too on the shield. I can confirm the issue is still present. I see vishal207 provided logs if you want some from me just let me know.
I have the same issue with Xaiomi Mi Box. Any channel live tv, after a few minutes the video stops and the little orange circle starts making live tv on Plex unwatchable.2020-09-21T04:00:00Z Had a message on screen about weak antenna signal. HDHR app fine. Good antenna signal.
Hardware Transcoding I5-9400 both hardware acceleration when available and hardware-accelerated video encoding checked.Plex Media Server Logs_2020-09-21_20-12-24.zip (5.5 MB)
Updated firmware on HDHR, no change but we are noticing problems with antenna and tv tuner, so may not be plex issue.
I am having LIVE TV issues with my nvidia shield client. iPhone, Roku Stick play back just fine but this way more expensive nvidia shield stops with a orange buffer circle and as soon as I touch the remote it tells me I have a weak signal…
I too updated firmware to the 0907 version when I first received the error.
Install plex beta on your other devices and see if they work.
My mobile devices no longer have the consumer error but android tv beta still does.
Same issue on plex for windows.
Thanks all for the responses so far!
@vishal207I checked your logs but they are a bit too cut off, any chance you could capture again keeping more of data in the past? I need to see some of the events leading up to the error. Thanks in advance :bowing_man:
@pshawman Just to confirm, you are also seeing the issue with the Plex windows app (not windows server)
Thanks again!
Confirmed. Issue is with the latest version 1.19 Rolling back to plex for windows 1.18 fixed the issue for 2 users.
This weekend I watched TV on my windows 10 PC for hours without interruption. So I’m on the app for windows 1.19 but don’t see the issue there… Don’t have any issues on iOS either. For us, only our firetv has this problem.
This is also an issue on xbox one.
LG Android mobile - beta does not fix error; reverting to previous Plex Android app 8.5.2.20133 per Tacoriffic (from here) works without playback error.
I’ve attached some logs
Error on 9/22 at ~1537
Plex Media Server.log (4.2 MB)
Nvidia.Shield.Logs-22_09-1537-8.7.0.20631-beta.txt (1.2 MB)
Some further insight with the beta:
-when tuning the channel. The error still occurs but not so readily.
-when turning the channel, then selecting ā€œplay original quality,ā€ then reselecting ā€œ1080p 20 Mbps.ā€ The channel plays for hours! I’ve had it streaming consistently after doing this.
-Sidenote: when tuning a channel (1080i --> 1080p) with the ā€œconvert automaticallyā€ option set, it does not show as a live stream on the dashboard, plexdash, or tatulli. The stream only displays after changing the quality.
