Problem:
You can restrict access to media through setting labels on clips/videos/movies. Then add these to each user.
When having more then one library. These restrictions apply to all libraries.
ex.
You have two Libraries:
- Movies
- Home Videos
You want your family to see all Movies. No restrictions on that Library.
But on Home Videos, you only want them so the clips for a family dinner. Not the fishing trip with friends.
If setting a label to the family dinner as “family-friendly”. Then under user add the label “family-firendly” under restrictions for ‘Movies’.
This rule will apply for all your Libraries. Which will end up removing all Movies in the Movie library.
Suggestion:
Option 1:
Be able to choose restrictions for each Library.
Option 2:
Be able to choose which library the label restriction apply for.
Remeber to Like this post if you would want to see this feature.
