Files not added to library
Hi, I have a media library of 77 TV shows, only 67 are showing up on my Plex Library. I have looked at the files that haven’t been picked up and there is nothing that differentiates them from the ones that have been included in the library. The file directory is correct - I have even tried creating new file path that points directly to a missing show folder but it still fails to recognise these files and update the library. Is there a maximum number of shows that you can include in a library or something?
generally is is only file naming that will cause a problem or if you are running linux then file permissions can cause folks issues.
What are your directory and file names like that are not showing up
