Finally agreed to switch to new Plex Agent.. what a mistake
OP take a look at the app Filebot. Will save you a ton of future headaches and correctly name your movie and TV shows.
While naming could generate problems, Plex itself has problems, even if the moderators try always to blame the user. I assume my names are OK because they come from Radarr/Sonarr. Still during the Agent upgrade Plex unmatched an unpleasant amount of movies that were already matched and they stayed unmatched. Of course the moderators are in this thread telling us that’s not possible. Well, what can I say?
What I expect from Plex and any other service like it is to honor the CORRECT naming. By this I mean for movies and TV shows I ALWAYS check TMDB and TVDB and use that as my guide for naming. The only time I check with other sources is if the two services have even the slightest difference in names for the item. I dropped Plex a good while back because of being told I had to name items different than what the official title is to get Plex to match them correctly. Was flat out told it had to be an enduser problem when I knew better. The difference between the Plex forums and the Emby forums is night and day. As far back as I can remember either the Plex forum staff chose not to help at all or in most cases put the blame on the enduser. That is beyond wrong.
Tried emby for a week…YUCK is my experience coming from Plex. Deleted it and will not be going back.
I’ve used Plex for over a decade and I feel pretty confident in saying Plex DOES honor the correct naming of Movies and TV shows. Are you sure YOU are using the correct naming for your media? I know users hate to be told they are the issue, but sometimes it’s the truth :slight_smile:
I can’t stress enough how useful Filebot is for Plex. You may THINK you are using the correct naming structures for your movies and TV shows until you try Filebot and do a match with TMDB.
Nearly every movie or TV show I’ve matched in the last few years has matched without issue because I stopped putting things that don’t belong in the file name.
Half the comments in here are ignoring the fact that I’m not importing a library fresh… this was an existing collection that has been fine for years with no matching issues. I am ignoring comments about user error, it simply is not the case. I too am a 10 year or so veteran user.
With that said, I have decided to nuke the entire movie DB, I was wasting too much time troubleshooting it and of course I saw your request for logs after I had already done this. Considering the fact that I was seeing a pattern of multiple mismatches in a row (and then it performing fine for a bunch) and refreshing wasn’t working to fix them in bulk, I decided to just kill the whole thing. Rematching all affected entries was just taking far too long to bother with. The last straw was a bug that wouldn’t let me change Agents - the one that says ā€œYour changes could not be savedā€ no matter what you do. I read that this could mean that the DB had somehow been corrupted so I said screw it and wiped it. To make sure this was fool proof, I used TMM to replace all [ ]'s with { }'s even though this has never been an issue before (those were for other platforms, title + year should be more than enough to match). It has reimported fresh without any mismatches that I have discovered so at least there’s that.
You are correct though, there’s no reason why swapping Agents and then refreshing metadata would lead to all the mismatches, they were already matched so it doesn’t make sense why they would suddenly unmatch? As mentioned, I’ve used Plex for 10 years (2013 I finally bought my Pass) and dabbled with other platforms from time to time in that exact format without issue. All movies are contained within their own individual folder, along with their relevant images/nfos, and nested under the title’s first character parent folder. I do this for things like TMM so I don’t have scan the entire collection when I want to force an update for a specific title.
Barring periodic backups for the DB, Plex really should respect local nfo files in the event a rebuild is necessary. It would have saved me so much time.
We’ve made it VERY clear it’s not us, deal with it.
From the one example above given of a movie file name it was very clear that was NOT the correct way to name in Plex. It would likely still match but could cause problems.
But yeah let’s just blame Plex and never look in the mirror. Smart choice…
I myself upgraded matching and had 0 movies unmatched in a medium-large size library. I’m on MacOS so not sure if it’s something OS dependent or not.
I’ll bow out of this convo as I haven’t experienced this issue. However I’ll say again to everyone who has issues with matching…Filebot is your friend :slight_smile:
Square brackets were the culprit to my incorrect matches so there is definitely a reason to avoid using tags inside square brackets.
Running a few test files isn’t nearly enough to verify anything - you need to do thousands of different files with proper naming + tags instead of random characters + tags.
Maybe your files are matching due to Plex not finding anything named abcdefg so it then searches within square brackets as there is no other name info to use? Who knows.
I haven’t noticed any issues since changing to { }so that’s a clear winner.
I agree, name 'em correctly, as per the documentation!
If nothing else, you get to be really righteous about it when there’s a problem and you ask for help. LOL :slight_smile:
I dunno why I felt it necessary to comment. I didn’t add anything to the discussion by saying ā€œsquare brackets kinda workā€, when I do strongly advocate for following the docs.
When I was testing, I found that putting an ID in square brackets or squiggly braces would override almost anything else. But that was a handful of test files, not a library of ā€œdifficultā€ things. I’d be interesting in knowing some of the filenames that didn’t behave that way for you.
Somebody - maybe MovieFan.Plex, or maybe drzoidberg33, or maybe OttoKerner - once stated that only the first set of brackets in a filename are ignored. I think that points out how complicated the filename parsing process is.
Thanks for the update. I’m sorry to have distracted!
RIGHT!, except you also have a PLEX NINJA telling you to get rid of the square brackets which would be what? … a naming issue. Sorry not sorry.
Just because one agent didn’t mind it doesn’t mean the new agent doesn’t.
Apparently the new agent doesn’t like square brackets … yea, weird huh.
What do you mean with ā€œtagsā€?
Plex doesn’t reads tags from file names at all.
If you need to put info into the file names which are not covered by the naming guides, you need to hide them from Plex. So they don’t throw off the scanner and lead to mismatches.
That is what the square brackets are for.
Tags as in IMDB/TVDB IDs. :slight_smile:
ahh IDs – not tags.
It is clearly documented how to indicate these properly: Naming and organizing your Movie files | Plex Support
Naming and Organizing Your TV Show Files | Plex Support
Might be of interest for some, regarding storage of metadata… mp4 files can be used to store metadata settings, even if you use an .mkv for the movie.
A .mp4 file can be used for the movie, or an empty .mp4 (no streams, just metadata) can be saved alongside the move (similarly named). The old Plex scanners have read the poster artwork, and certain tags from the .mp4 metadata, to populate various details in the home page for the movie, when the movie is added to the library. This could be very useful if the library needed to be rebuilt from just the files.
mp4 metadata I found to be read by Plex are:
Poster artwork: {equivalent to the poster.ext file}
Name: {Must match the TMDb title}
Genre: {Up to two comma separated text fields}
Release Date: YYYY-MM-DD {Year must match TMDb title. Use that, in preference to the TMDb release year, if they don’t match.}
Long Description: {Can be fairly long and verbose. Length limit unknown. One long line. Separate paragraphs merge into one}
Studio or Copyright: {If Studio info exists, it will be displayed, otherwise the the Copyright info will display in the ā€˜Studio’ line of the movie homepage.}
Director: {comma separated list of Director names}
Screenwriters: {comma separated list of Writer names}
Cast: {DO NOT USE! a comma separated list of actor names, but using this field breaks the photo image for the actor, even if you remove the Cast: tag from the MP4. (I tack on a list of actors in the Long Description)}
Tools for editing metadata of .mp4 files:
macOS subler.org - Subler
Windows danhinsley.com - MetaX
I use Subler and can’t vouch for how well MetaX works with Plex.
It’s a lot of work putting your meta data in an MP4 file, but it will pay off the first time your Plex database becomes corrupted and you have to rebuild from scratch. I wish there were similar side loaded files were we could define things like Collections and Playlists.
I don’t know how the new scanners will deal with MP4 metadata, but I hope it continues to work. I monitor this topic with keen interest and am holding off refreshing all my metadata, hoping that the problems iron themselves out.
Sorry, but Plex does not respect metadata in the file even when that option is checked. It’s not rocket science logic to look at metadata in the file for season number and episode number. Relying on file naming as a first and/or last resort when there is metadata in a supported container format is just plain bad design.
It would be one thing to mismatch a series name. But if the series name is matched correctly but the season and episode numbers are ignored then I just am a loss for words. Yet, that’s what I often experience.
Here’s the logic I recommend:
  1. Match on series. Let me override this in the UI. Then store that in the database.
  2. Next, match on the season. Let me override this in the UI. Then store that in the database.
  3. Next, match on episode. Let me override this in the UI. Then store that in the database.
My workflow is simple. I convert to m4v container with appropriate supported codecs. I add metadata with Subler from thetvdb.com or tmdb.com. I add the files to iTunes / Apple TV library. I point Plex at the folders for that library - separating Movies and TV libraries. Then Plex manages to - sometimes - completely ignore the metadata.
Why?
Google dropped me off here… tried to read through all this before posting.
I too just converted to the ā€œnewer fasterā€ Plex agent at the request of a pop-up on Mac. It ran through my entire 1000+ film collection, no problem. Not one issue cropped up. BUT, and it’s a BIG BUT, now I can’t add any new movies. It straight up refuses to match any movies I add. I don’t know what changed (not a cool code monkey), but nothing is matching when I add a new film.
And I’m not adding indie unground goth fetish movies… ā€œFantastic Four (2005)ā€ is about as mainstream (with correct naming convention) as it gets. I even tried various other variations using { } and brackets. Even went so far as to try out Filebot. Nothing. No matching love.
Assuming it’s not user error (that was my first card played), what else could it be? For science!
The main problem with the new agent is the only agent available. It is fast but not complete. Lots of popular shows are not in the DB. It merge a lot of TV shows that not listed in the DB to other TV shows. Unfortunately Plex do not handle TV duplicates well. In general marking duplicates is non existence since few updates back.
Double check you’re TV shows and movies to make sure it not merged with other TV shows and movies. The new system is a pain.
Well, that’s weird; it started matching again this morning. Didn’t do anything more than let it sleep over night. Must be a gremlin in the system or it was doing something in the background. Either way, back to normal.
There was an issue that we picked up this morning where some newer shows were not getting picked up (this was a recent regression). This should be resolved in the next day or two.
Could you give me an example of some of the shows that aren’t matching for you?
tested it for 1 month but…
it doesnt work at all… 90% of my content ( 358 series ) is matching to ā€˜Zero One-Once in Adana’…
many series are combined and twisted ( sometimes it adds one episode from another series that is in a complete different directory ).
all names are identical to the tvdb entry names ( worked for over 4 years almost perfectly ) so there is no problem on my side.
another problem that came with the new agent ( and the new synology major version update ), sometimes files and directories are ignored - you need delete the file and copy it again a few times until plex register it and you see it in the notification log
examples for series that doesnt match: The Vampire dies in no time, Mieruko-chan, The Worlds Finest Assassin, Banished from the Heros Party.
edit: here is my full path to series ( no special stuff, just the tvdb name ): ā€œ[…]\Storage\Animes\Mieruko-chanā€
