Server Version#: 1.22.3.4523
Player Version#: web client 4.54.5
Hi there,
I’m trying to match a TV serie by using its ID from thetvdb.com, as described here (go to bottom) : Fix Match / Match | Plex Support
I’m trying to match the serie ID 262975 (french).
It finds no result
What am I doing wrong ?
Any help is appreciated
There seems to be some hiccup if a show is listed as a movie on TheMovieDatabase.org. Or as in this case where the show is not listed on TheMovieDatabase.org at all… they only got a “movie”
Apparently the new scanner/agent needs the show to be at least listed on TheMovieDatabase.org for it to be matched (though it might rely on TheTVDb.com for subsequent metadata assignment).
As a workaround, I edited the related library to use specifically the agent scanner “TheTVDB”.
Now the search by ID is working as expected.
