Fix [Unknown Album] in music library
Server Version#: 1.14.1.5488
OS: Win 10 64bit
Hi, I would like to know if someone knows how to fix [Unknown Album] in music library.
I checked for inconsistent tags but all seems to be correct, all files are in FLAC format.
Any help would be appreciated, thanks.
How are your files named?
Did you put them into a folder structure?
How did you ā€˜tag’ your files?
Is this an album that is rather obscure?
Do you know the correct album title yourself?
Here are some tips regarding music
multi-disc albums
handling singles and EP’s
https://forums.plex.tv/t/best-way-to-add-album-singles-ep-to-a-premium-music-library/128108/8
possible ā€˜side car’ files for music
soundtracks and ā€˜various artists’
First of all thank you for answer.
- How are your files named?
files are named Track n. - Title.flac
- Did you put them into a folder structure?
The folder structure is /Artist/Album/Track N. - Title
Multi-disc structure is: /Artist/Album/CD Disc n./Track N. - Title
- How did you ā€˜tag’ your files?
I use Mp3Tag and MusicBee, other than common tags like Artist, Title, Album etc…, I store other album informations in some less common tags like Original Year and in completely custom tags.
- Is this an album that is rather obscure?
The album title is quite common but since I have different versions of the same album I usually title albums this way: Album Title [version text ex. ā€œRemasteredā€ or ā€œLimited Editionā€ and so on].
- Do you know the correct album title yourself?
I’m not sure about what you mean but yes, I keep a very precise and consistent music library.
OK.
Your folder structure is perfect. The track names will work, as long as you have correct meta tags.
May I ask which file format you are using in your library?
Because Plex can read meta tags only from some file formats.
Since you are meticulously tagging your files, it is best to tell Plex that it shall use your meta tags as the primary means to ā€˜match’ your music.
How to do that, is covered in the second half of the 2nd link posted above.
Custom tags are not read by Plex.
If you want complete control over what Plex is recognizing as an ā€˜Album’, you should absolutely use and populate the standard tags for
  • Disc #
  • Track #
  • Album Artist (only necessary if one or more tracks on an album use a ā€˜track artist’ that is different from the album artist)
  • Album Title (Must be absolutely identical in every track in one album. Things like ā€˜Disc 1’ or ā€œdisc namesā€ don’t belong in here.)
  • Track Artist
  • Release year/date
After making the configuration changes in the Agent and library properties, perform the Plex Dance with all albums of one particular Album Artist.
Thank you for your help, I followed all your advices and instructions and finally all worked well, I don’t know what caused the problem, anyway it is solved.
Have a nice day.
