Server Version#:latest
Player Version#:latest
Does anyone have a Folder naming and file naming guide link? I’m a newbie and want my TV shows to display correctly. Thx - bob
Thx, but how do i turn off PLEX from synching with my TV shows while I go back to my HDD on the server and re-name the files and folders?
Well, typically you move the show out of the library, work on it, then put it back - kinda in the middle of The Plex Dance:
But… you can reserve The Dance for shows that misbehave after you rename them and ‘Refresh Metadata’.
Before you start this - do this:
That will prevent Plex from giving priority to embedded Title Fields (the bogus Titles that make your life miserable), preferring them over a perfect file name and structure - if you have any of those.
In the ideal situation - you want to start with good file names and structures.
When you have to fix them in mid-flight - there’s always that question: is my bundle good?
I answer that question with a Plex Dance - it’s a bundle Do-Over.
Sorry, I’m a newbie and many of the terms you are using are foreign to me. Here’s the bottom line. I edited the file and folder names already when they were inside the HDD that was pointed at PLEX.
So, the horse is out of the barn. Am I screwed? Or can I move the files and folders out of the directory pointed at PLEX and somehow flush the PLEX cache?
You’ll be fine.
Move LMA as described under ALL tabs in Shows and Movies.
Rename and Restructure your files according to the packaged directions.
Refresh Metadata at the show level Not the episode or season level.
If nothing good happens - Plex Dance the Show - All steps as they’re described, in the order given - or it simply won’t work.
LMA = my TV shows, right?
Where is “under ALL tabs in Shows and Movies?” Can you give specific instructions where to find it?
Where do i find the Refresh Metadata?
What is “Plex Dance the Show?”
Read the links - explained in painful, horrifying details:
Server/Settings/Agents
Shows: TVDB/TMDB - move LMA to the bottom of the list of active agents
Movies: Plex Movie/TMDB - move LMA to the bottom of the list of active agents
If you want that ‘good feeling’:
Create a new TV Show Library Folder - and a New TV Show Library.
Move Shows OUT of the existing TV Show Library
Scan Library
Empty Trash
Clean Bundles
Fix Show names and structures
Put show in new TV Show Library.
Rinse/Lather/Repeat
Eventually your old tv show library will disappear - when there’s nothing more in it - then you can delete that old Library. Your new TV Show Library will have all good stuff in it - with nice clean bundles.
The new stuff will be good out of the gate.
No worries.
JuiceWSA,
I’m not seeing ALL TABS in my plex client. Please advise.
Plex Movie
The Movie Database
Under Shows:
TVDB
The Movie Database
Ya gotta read the instructions, look at the pictures, aim your mouse and click.
Juice, no matter where I click in my PLex client I can’t find the screenshot you are showing. I’m on a WIN 10 desktop using a chrome browser.
Click the ‘Tools’ - upper right.
down the side bar find Agents
Look familiar?
That’s not Plexweb.
http://127.0.0.1:32400/web/index.html#
That is.
Right click the Plex Icon in the system tray and ‘Open Plex’
That’s Plexweb too.
I am left clicking on the tool icon and it does nothing.
Well - I don’t know of any other way to get to the settings.
And there’s not much sense in continuing if you can’t get to the settings.
I will now stand down.
I don’t know how to fix that.
I am a user, just like you, but the difference is when I click the tools I go to Settings.
This is your image and it shows you in the settings:
To the left is a side bar and if you scroll down, you’ll find Agents.
