Is there a trick to force ac3 5.1 to be downmixed to 2 channel? My TV doesn't decode ac3 and any file I have with the ac3 5.1 audio codec plays without sound. I tried setting "Dolby Digital" in the atv settings to off and also left the "enable Dolby Digital on Apple TV" option on PMS unchecked.
Yeah, I noticed most folks go the other direction, trying to get ac3 to work. I tested the ac3 in another room with an audio receiver and it works fine, I just can't make it stop working. :blink:
Here's a fresh PMS log trying to play a ac3 file. The atv2 Dolby Digital output was set to NO and the PMS advanced transcoder option to support atv ac3 was unchecked.
@nutcais: Does the source file have a stereo track in it? I have some problems on ATV (without Plex!) where I have to have both stereo and AC3 tracks/streams in order for it to play on ALL devices.
f00b4r sounds like he can help with the Plex-specific angle, which is what you want, but it might be worth checking if the source has a stereo track in it. It's pretty easy to add one, if you're comfortable running commands in the Terminal.
The files in question, and tested, only have ac3 5.1. I suppose I could manually add an aac 2 channel track, but that's a lot of work for the all the ac3 files I have.
The PMS should automatically transcode to stereo if eg only a DD/DTS track is present.
Indeed. PMS is working correctly on DTS 5.1 mixdown, I've checked. I'm still messing around, maybe I'll get lucky and find the right combo of PMS, PlexConnect, and settings to make this thing work. :)
Try this version of PMS (it was the first to introduce support for 5.1 sound with PlexConnect and the universal transcoder and would immediately point to a PMS bug in newer versions if it works for you:
On the server side, I have a Windows 7 Ultimate (64bit) box running PMS and PlexConnect pulling files from a NAS via SMB.
On the player side, I have an Apple TV 2 (v6.0.2) connected to a Panasonic plasma via HDMI. I also have an audio receiver (logitech z5500) that can decode ac3 connected via optical toslink that I moved into the room for testing.
Try downloading 0.9.7.28 - the first publically available PMS to support switching stereo downmixing on and off with PlexConnect.
Same thing...No sound output through the TV.
So .mkv files with ac3 are being downmixed properly, my guess is they are being remuxed due to the mkv incompatibility with the atv2. I also though it may be a problem with my test files (I encoded them) so I downloaded one from here. It's the "AC3-only M4V" file. It does not get downmixed either.
Could you verify that the test file I linked plays for you in 2 channel stereo? I'm curious if I have an Apple TV problem rather than a plex/plexconnect problem.
