Fragen zu Plex Apple TV 3
Na gut, ich probiere es weiter.
Mit der Übertragung des Zertivikates auf aTV hab ich immer noch keine Lösung gefunden.
hie mal meine log Datei:
17:18:53 PlexConnect: started: 17:18:53
17:18:53 PlexConnect: IP_self: 192.168.178.29
17:18:53 DNSServer: started: 17:18:53
17:18:53 DNSServer: ***
17:18:53 DNSServer: DNSServer: Serving DNS on port 53.
17:18:53 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.178.29
17:18:53 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
17:18:53 DNSServer: forward other to higher level DNS: 8.8.8.8
17:18:54 WebServer: started: 17:18:54
17:18:54 WebServer: ***
17:18:54 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
17:18:54 PlexGDM: ***
17:18:54 PlexGDM: looking up Plex Media Server
17:18:54 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
17:18:55 PlexGDM: servers discovered: 1
17:18:55 XMLConverter: PlexGDM - PMS: 192.168.178.29:32400
17:19:01 DNSServer: DNS request received!
17:19:01 DNSServer: Source: ('192.168.178.23', 56980)
17:19:01 DNSServer: Domain: time.apple.com
17:19:01 DNSServer: ***forward request
17:19:01 DNSServer: -> DNS response from higher level
17:19:02 DNSServer: DNS request received!
17:19:02 DNSServer: Source: ('192.168.178.23', 57495)
17:19:02 DNSServer: Domain: init-p01st.push.apple.com
17:19:02 DNSServer: ***forward request
17:19:02 DNSServer: -> DNS response from higher level
17:19:03 DNSServer: DNS request received!
17:19:03 DNSServer: Source: ('192.168.178.23', 63452)
17:19:03 DNSServer: Domain: 50-courier.push.apple.com
17:19:03 DNSServer: ***forward request
17:19:03 DNSServer: -> DNS response from higher level
17:19:13 DNSServer: DNS request received!
17:19:13 DNSServer: Source: ('192.168.178.23', 50999)
17:19:13 DNSServer: Domain: ax.init.itunes.apple.com
17:19:13 DNSServer: ***forward request
17:19:13 DNSServer: -> DNS response from higher level
17:19:14 DNSServer: DNS request received!
17:19:14 DNSServer: Source: ('192.168.178.23', 50425)
17:19:14 DNSServer: Domain: itunes.apple.com
17:19:14 DNSServer: ***forward request
17:19:14 DNSServer: -> DNS response from higher level
17:19:15 DNSServer: DNS request received!
17:19:15 DNSServer: Source: ('192.168.178.23', 59875)
17:19:15 DNSServer: Domain: a1.phobos.apple.com
17:19:15 DNSServer: ***forward request
17:19:15 DNSServer: -> DNS response from higher level
17:19:15 DNSServer: Source: ('192.168.178.23', 64287)
17:19:15 DNSServer: Domain: a1.mzstatic.com
17:19:16 DNSServer: DNS request received!
17:19:16 DNSServer: Source: ('192.168.178.23', 49310)
17:19:16 DNSServer: Domain: configuration.apple.com
17:19:16 DNSServer: ***forward request
17:19:16 DNSServer: -> DNS response from higher level
17:19:16 DNSServer: Source: ('192.168.178.23', 60884)
17:19:16 DNSServer: Domain: a5.mzstatic.com
17:19:16 DNSServer: Source: ('192.168.178.23', 57971)
17:19:16 DNSServer: Domain: a2.mzstatic.com
17:19:17 DNSServer: DNS request received!
17:19:17 DNSServer: Source: ('192.168.178.23', 55987)
17:19:17 DNSServer: Domain: a4.mzstatic.com
17:19:17 DNSServer: ***forward request
17:19:17 DNSServer: -> DNS response from higher level
17:20:26 DNSServer: DNS request received!
17:20:26 DNSServer: Source: ('192.168.178.23', 53870)
17:20:26 DNSServer: Domain: s.mzstatic.com
17:20:26 DNSServer: ***forward request
17:20:26 DNSServer: -> DNS response from higher level
17:20:42 DNSServer: DNS request received!
17:20:42 DNSServer: Source: ('192.168.178.23', 57364)
17:20:42 DNSServer: Domain: trailers.apple.com
17:20:42 DNSServer: ***intercept request
17:20:42 DNSServer: -> DNS response: 192.168.178.29
hab erst Netzkabel, aTV Boot abwarten, dann USB anschliessen so gemacht, negativ.
MfG klaus2201
Ohne Zertifikat hilft auch das LOG nichts...
Wo ist das Problem? Apple Config Manager oder iPhone Utility? MacOS oder Win?
USB Kabel richtig reingesteckt?
Ich habe Win7 64. Das Problem habe ich mit dem Iphone Utility.
So, jetzt funktioniert Plex. Ich hab es irgendwie geschafft, das Zertivikat auf aTV3 zu installieren.
Nun kann ich wieder ruhig schlafen :slight_smile:
MfG klaus2201
schafft der aTV 3 alles ruckelfrei zu spielen? 1080p und hohe bitrate?
Auch DTS Tonformat?
Also bei mir läuft alles problemlos. DTS weiß ich nicht genau.
