So I came across this weird problem, that frequently mismatches movies with long and weird meta information titles.That means, that a movie file called “XY.mp4” will be matched as “XY.2016.1080p.WEB-DL.DD5.1.H264.FGT” in Plex Media Server and appear as such in all media players. Otherwise the movie is matched correctly (poster, trailers, information, etc.) None of the data I supply contains any of the information that shows up.
Anyone else have this problem or any idea what’s going wrong here? Maybe one of the databases used for matching is acting up?
Sounds like you are picking up metadata from inside the mp4 files.
Try moving “local media assets” to the bottom of all your agents.
The you will need to perform the Plex dance:
Thanks. I tried moving the “local media assets” and will keep an eye on it. Since I do stick to the Plex dance scheme and most of the files work, I think this could have been the issue.
Thanks @trumpy81. I’ll be sure to give it a try!
