Full screen green playback on original quality
Server Version#: 1.41.7.9799
Player Version#: 4.146.0
Playing back a video in original quality shows nothing but full screen green. Audio playback is not affected. Selecting to convert to ANY of the 1080 profiles still results to green screen. Selecting the 720p HD profile results in a clear image of the content. Going off from this I have to assume that the video is fine, as at least in one way, the plex server can see the proper video images since it’s able to produce them in teh 720pHD profile.
The Get Info details of the file are:
  • Codec H264
  • Bitrate 10041 kbps
  • Bit Depth 8
  • Chroma Location left
  • Chroma Subsampling 4:2:0
  • Coded Height 1088
  • Coded Width 1920
  • Color Primaries bt709
  • Color Range tv
  • Color Space bt709
  • Color Trc bt709
  • Frame Rate 29.97 fps
  • Height 1080
  • Level 4.0
  • Profile high
  • Ref Frames 4
  • Scan Type progressive
  • Width 1920
  • Display Title 1080p (H.264)
  • Extended Display Title 1080p (H.264)
  • Codec EAC3
  • Channels 2
  • Bitrate 224 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout stereo
  • Sampling Rate 48000 Hz
  • Display Title English (EAC3 Stereo)
  • Extended Display Title English (EAC3 Stereo)
From the version, I presume you are using a browser. Your symptoms likely mean that your hardware decoder cannot decode the original file but is able to decode a transcoded version. Although your paste of the file info doesn’t indicate anything difficult for hardware to decode unless the hardware is very old.
Perhaps you should try disabling hardware decoding in the web player to see if that makes a difference.
None of these options state anything about hardware decoding
Where would that option be?
Sorry, I forgot that the web client doesn’t have that setting. It’s using the playback engine in your browser so this would be a browser level setting.
