Server Version#: 1.28.2.6106 (TrueNAS Core, manual install in a jail)
Player Version#: Android 9.7.0.34811 (e3f8b122) - also the latest web version from another computer
While my remote access settings tells me constantly that it’s “Fully accessible outside your network”, my Android phone can’t connect to it while on LTE, and my laptop can’t connect to it either while going through my phone’s LTE connection by wireless tethering.
I’ve tried the following:
Using UPnP and not specifying a port in Plex
Not using UPnP and manually specifying a port, forwarding it through my router
Disabling my router’s firewall
Ensuring that my router’s DNS client points to Google’s DNS server
Setting a DDNS service on my router
Reboot the router
Clear the data in my Android apps and log in again.
It seems the issue is happening on my end only, as after the troubleshooting steps I’ve mentionned before, a friend of mine was able to stream with his phone on the cellular network.
Here are some server logs that seem to reveal that it’s an issue with the secure connection:
Aug 28, 2022 13:23:59.933 [0x806814300] Debug — CERT: incomplete TLS handshake from [::ffff:142.169.18.26]:32648: stream truncated
Aug 28, 2022 13:24:30.023 [0x806814300] Debug — CERT: incomplete TLS handshake from [::ffff:142.169.18.0]:40549: stream truncated
Thanks for the fast reply. I’ve just tried with my iPad on a public wifi and it worked. I think it’s related to my phone at this point. I’ll try the troubleshooting later.
Before starting the troubleshooting… check out what information are being shown on the “Now Playing” tile of the server’s dashboard while you’re streaming remotely from your iPad. If the connection is showing as remote, you should be good – if it’s showing as indirect you can give that troubleshooting some look.
Otherwise it could be as simple as your mobile data provider blocking certain ports or types of communication.
I’ve asked a friend to stream from their home and it did say Remote. I think the problem really is in my phone or the carrier. I’ll check that out on my end. Thanks!
As we both are in Quebec, Canada, I was on Koodo (Telus network) and he was on Videotron. Not long ago, I was on Fizz (Videotron network) but I came back to Koodo, as I preferred that carrier overall, and if I recall correctly, it used to work on Koodo as well before I switched to Fizz.
So yesterday I’ve called Koodo and after some attempt at resetting my own LTE connection on their end, it did not fix the issue, and that the problem is not on their end. It seems there’s an issue in either my server, my phone app (even after reinstalling it) or the Plex service itself.
I went through the troubleshooting guides and they didn’t help. I couldn’t check the Double-NAT situation as I couldn’t get my phone’s IP, but it could connect to another application in my server.
I got the log from my Android app and I feel like these two lines can help.
09-18 16:31:22.229 i: Time out fetching https://172-105-98-20.4c55a73e637a439f9efb91599e3955e1.plex.direct:8443/media/providers?includePreferences=1&X-Plex-Token=...rAU.
09-18 16:31:22.231 w: [MediaProvidersApiClient] GAB-PLEX Couldn't fetch providers. Result: Error (null)
To what exact findings did you go through them?
Starting with… is your router accessible using its public / WAN IP address and the port from your port forward?
