Functionality Questions - Am I stupid?
Hi all, In Australia we have SD and HD channels that use the same guide data however when configuring the channels I can’t create duplicates - it throws an error until I disable one of the channels. Is this behaviour expected? I feel like we should be allowed to tune both if we want and set guide data to the same.
Second problem is a really frustrating one that myself and SO can’t get our heads around, why isn’t there a way to display channel names and numbers in the Live > Program Guide view. Sure it says the name of the currently running program but we don’t necessarily care about what the guide thinks is on we just want to jump to a specific channel. MythTV is so much better in this regard - can we see some improvements, are there any options I can configure to make this work?
On top of the no channel names issue, if guide data can’t be mapped then that channel can’t be used… this is stupid and annoying as we have channels with no guide data.
Cheers,
Justin
EPG is being worked on and will provide a better user experience but no timeline is available.
I use the HDHR viewer myself as it provides a better user experience for live TV at this time. If you use HD homerun that might help.
As far as SD and HD I have both and both display for me with the same guide data.
