FYI - WD MyCloud home Plex is down
If, like me, you are unlucky enoughg to run your Plex off a WD MyCloud device, you may notice it is showing as offline. This is not you, but them.
since Sept 30 WD have had an outage that has taken their services down. As of my posting, there is no idea when it will be resolved.
You can see their status by visiting http://status.mycloud.com/os4
Hopefully back online soon.
J
Unplug the My Cloud Home power for 5 seconds or so, then plug it back. It will not update right away, but if your internet is up, it will update in about 15 minutes. It went off line for about 1 to 2 hours earlier depending on where you are located and how quickly you performed the power cycle.
The software version is now 7.15.1-101
10/1/2021 1:24:49 PM ET
