Watching some content in (H.264 High 10) on Plex with 2nd Generation Firestick I have weird effect.
Lot of pixeling, colour variation image washed out.
Same content on VLC is perfect, with Emby also ok.
Why? Should I post some data? Which oes?
Go into firestick settings, and make sure H.264 level is not set to 1.0, set it to 5.2 (I think that’s the right one). There was a bug that may not have been corrected automatically for you.
If that doesn’t work, just know that the firestick tv app has been broken for like a week or two and they’re working on all the issues.
Hi, thanks for suggestion, level set is 5.2, was 1.0 (defautl setting). But also with 5.2 same issue.
Waiting then for the fix, as they are aware of this problems, thanks
