Hardware transcoding not working with 4k UHD files
Server Version#: 1.28.2.6106
Player Version#: Unknown
Hardware transcoding does not work with 4k H265 UHD files. It seems to function normally with 1080p/H264 sources.
Getting these errors in the log
[AVHWDeviceContext @ 0x7f0e2e802000] No matching devices found.
Reinstalled plex and it seems to think that things are OK
PlexMediaServer install: PlexMediaServer-1.28.2.6106-44a5bbd28 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: render
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp (set in Preferences.xml)
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Processor: Intel(R) Core™ i7-9700 CPU @ 3.00GHz
PlexMediaServer install: Intel i915 Hardware: Found
PlexMediaServer install: Nvidia GPU card: Not Found
PlexMediaServer install: OpenCL: Installed
PlexMediaServer install: Beignet: Installed
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: PlexMediaServer-1.28.2.6106-44a5bbd28 - Installation successful. Errors: 0, Warnings: 0
But it’s still not working
Disabling tone mapping fixes it but that’s not a great solution.
It’s a known issue. Downgrading to 1.28.0 is the current workaround.
What’s a good version in 1.28.0 to use. Could you help with a download link?
Assuming you’re running linux (ubuntu/debian etc.) try https://downloads.plex.tv/plex-media-server-new/1.28.0.5999-97678ded3/debian/plexmediaserver_1.28.0.5999-97678ded3_amd64.deb
Thanks!
There’s also a development build of 1.28.3 that fixes the issue
https://artifacts.plex.tv/plex-media-server-experimental/1.28.3.6101-cd5349651/debian/plexmediaserver_1.28.3.6101-cd5349651_amd64.deb
Even tried upgrading to the latest plexpass 1.29, and it’s broken. Jeezus.
Thank you, saved my ass when a user complained.
Downloaded .0 from your url, and placed a apt hold on plexmediaserver, going to lock down on this version and forget about it for the forseeable future
Christ, it STILL isn’t working. wtf have they done.
Chuck told me that 1.29 needs the most up-to-date version of ICR to work with hardware transcoding, but it did not work for me. I posted logs and still have not heard anything back.
@KyleD324 and all
I’ve not gone deep into 1.29.0 because, as I started, I was asked to test 1.29.1.
In a nutshell, without saying more than I should … PMS 1.29.1
I have been testing it now for the past few days.
As evidence:
[chuck@lizum ~.2001]$ ssh nuc10
Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 5.15.0-48-generic x86_64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
11 updates can be applied immediately.
3 of these updates are standard security updates.
To see these additional updates run: apt list --upgradable
Your Hardware Enablement Stack (HWE) is supported until April 2025.
Last login: Fri Sep 23 10:26:43 2022 from 10.2.15.100
[chuck@NUC10i5FNK ~.213]$ uname -a
Linux NUC10i5FNK 5.15.0-48-generic #54~20.04.1-Ubuntu SMP Thu Sep 1 16:17:26 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
[chuck@NUC10i5FNK ~.214]$ cat /proc/cpuinfo | grep 'model name' | uniq
model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
[chuck@NUC10i5FNK ~.215]$ [chuck@lizum ~.2001]$ ssh nuc10
[chuck@NUC10i5FNK ~.215]$  dpkg -l | grep plexm
ii  plexmediaserver                            1.29.1.6221-eee1f83e4               amd64        Plex organizes all of your personal media so you can easily access and enjoy it.
[chuck@NUC10i5FNK ~.216]$
----- AND -----
[~] # cat /proc/cpuinfo | grep model\ name | uniq
model name	: Intel(R) Celeron(R) N5105 @ 2.00GHz
[~] # ps -ef | grep -i plex
16413 admin     56188 S   ./Plex Media Server
16428 admin     36124 S N Plex Plug-in [com.plexapp.system] /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-eee1f83e4/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6221-eee1f83e4 /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-eee1f83e4/System.bundle
16502 admin      6936 S   /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Plex Tuner Service /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Private /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Tuner/Shared 1.29.1.6221-eee1f83e4 32600
19911 admin       100 S   Plex EAE Service
22444 admin       916 S   grep -i plex
[~] # hostname
QNAP-TS264
No questions, no questions please :sunglasses: :rofl:
After this is released, I will answer everyone’s questions. (sorry)
