Has anyone found that the EPG isn't loading which impedes DVR setup?
I think i asked my question poorly… I have a xmltv link from my provider, and have added it when setting up the DVR. It loads all the channels but all the TV shows are listed like a movie and never has any episode numbers, and can only add the recording as a Movie. So… my question is, does that bypass everything the PLEX EPG does, or should any issues i have still be reported? My feeling is it bypasses PLEX data until it needs to be matched after recording, my hope is there is something in plex that can help me…
I think the best is to report it to your xmltv provider. We had other examples of xmltv where season and episode info was missing
eg XMLTV format to be used in Plex
having a similar issue:
Managed to locate the local EPG but it cant seem to get any data from it, constantly refreshing at 0% and not showing any channels even though it found them before and I can view them perfectly fine if I connect to the HD Homerun directly.
Three Mobile !
See
I think that might have solved it, I used a different provider and was able to update the guide. I’ll drop a msg to 3 and see if they can find out whats going on with that address.
I have this problem, I am with three. Advised to ensure that my router (AI cube) is set to 3g only.
This works but im not happy being on slow-mo just for EPG
Three claim that this is not an issue not (it was and is still)
I have found another solution using mc2xml
How can they say that
i have tried to follow up again and they say that there is no issue -im hoping I can start totie this up over the summer. could be a deal breaker!
