Has anyone got a guide on using Plex with Scaleway VPS and Rackspace cloud files?
Hi All,
I’m not having much luck using Plex Cloud, I’ve uploaded all of my content, set it up as per the destructions, and still haven’t been able to use it? So…
I’ve decided that I might like to have a go at setting up my own Plex Cloud Server using Scaleway VPS and Rackspace Cloud Files. I guess I’ll have to use rclone too?
Has anyone done this, and if so, have you got any tips or a guide on the best way to set up my server this way?
Thanks in advance.
JP
Seems expensive
Why not just use gdrive or ACD, mount it and use that?
You will most likely find that any “cloud” solution will in the end cause inconsistent playback, but if thats really the way you want to go, gdrive or ACD is probably cheaper then this Rackspace Cloud Files solution.
I’ve tried using One Drive for my Plex Cloud files, I get zip whenever I fire it up? I will try using the G-drive option before I go down the VPS route, but I’m just wondering if it’s worthwhile really?
