Hauppage Dual Tuner Compatiblity Broken?
Server Version#: 1.13.8.5395
Player Version#: Web Client 3.67.1
So I’ve been following the BETA branch for about a year and have had decent luck with my Hauppage Dual Tuner in both recording and “live” view of local channels.
I noticed recently that none of my shows are being recorded and also that the Web Client cannot tune to any station at all within the Plex Guide. The error I keep receiving is : Error Code S1001 (Network).
I’ve tested the Hauppage device separately using the provided WinTV application and all looks well there.
What’s going on with Plex compatibility with these Hauppage devices?
Same here on Windows 10 as the server with Plex 1.13.9.5439 on the server.
Can prove the Hauppage works outside of Plex, but Plex DVR is essentially useless right now as I cannot tune into any channel.
I am able to delete the DVR, add it again, fully rescan and see all channels available. But if I try and watch any program then I get the s1001 error. I wondered whether this was a pure video issue (would “viewing” a radio station work?) but it simply affects all broadcasts that I’m trying to consume via the Hauppage USB Dual.
I’m still having the problem and haven’t seen anyone other than us bringing it up. Maybe we need to open a bug report?
It is trivially reproducible, but I cannot see a way to open a support ticket or bug report. Everything just directs me back at the knowledge base or the community forums.
These lines from the Plex Media Server.log line seem pertinent:
Oct 22, 2018 06:35:19.826 [9804] DEBUG - Request: [192.168.1.10:51340 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (8 live) TLS GZIP Signed-in Token (REDACTED)
Oct 22, 2018 06:35:19.829 [9804] DEBUG - Beginning read from two-way stream.
Oct 22, 2018 06:35:20.431 [10100] ERROR - [Transcoder] http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0265%230013973690%23/media/triplet%3A%2F%2F9018%3A4164%3A4164?param=%3C%3Fxml%20version%3D%221%2E0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3Ctunedata%3E%3Ctt%3E4%3C%2Ftt%3E%3Cdq%3E0%3C%2Fdq%3E%3Cdr%2F%3E%3Cfr%3E489833%3C%2Ffr%3E%3Cmd%3E0%3C%2Fmd%3E%3Csr%3E0%3C%2Fsr%3E%3Cpl%3E0%3C%2Fpl%3E%3Clf%3E8%3C%2Flf%3E%3Cl1%3E0%3C%2Fl1%3E%3Cl2%3E0%3C%2Fl2%3E%3Cls%3E0%3C%2Fls%3E%3Cpp%3E0%3C%2Fpp%3E%3Chz%3E0%3C%2Fhz%3E%3Cin%3E0%3C%2Fin%3E%3Cfc%3E0%3C%2Ffc%3E%3Ct%3E4164%3C%2Ft%3E%3Cn%3E9018%3C%2Fn%3E%3Cs%3E4164%3C%2Fs%3E%3Cen%3E0%3C%2Fen%3E%3C%2Ftunedata%3E%0A: Unknown error
Oct 22, 2018 06:35:20.438 [4444] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 6880 is 1 (failure)
Oct 22, 2018 06:35:20.438 [6640] DEBUG - Using default transcode duration of 120 minutes
Oct 22, 2018 06:35:20.438 [6640] DEBUG - Started session successfully: e076aec4-20e6-40e0-a412-66fff711f66a
Oct 22, 2018 06:35:20.438 [6640] DEBUG - DVR:Recorder: It took 5.2 sec to start the session for http://127.0.0.1:32600/devices/compound_device041dvb%23bda%23usb%23vid_2040%26pid_0265%230013973690%23/media/triplet%3A%2F%2F9018%3A4164%3A4164?param=%3C%3Fxml%20version%3D%221%2E0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3Ctunedata%3E%3Ctt%3E4%3C%2Ftt%3E%3Cdq%3E0%3C%2Fdq%3E%3Cdr%2F%3E%3Cfr%3E489833%3C%2Ffr%3E%3Cmd%3E0%3C%2Fmd%3E%3Csr%3E0%3C%2Fsr%3E%3Cpl%3E0%3C%2Fpl%3E%3Clf%3E8%3C%2Flf%3E%3Cl1%3E0%3C%2Fl1%3E%3Cl2%3E0%3C%2Fl2%3E%3Cls%3E0%3C%2Fls%3E%3Cpp%3E0%3C%2Fpp%3E%3Chz%3E0%3C%2Fhz%3E%3Cin%3E0%3C%2Fin%3E%3Cfc%3E0%3C%2Ffc%3E%3Ct%3E4164%3C%2Ft%3E%3Cn%3E9018%3C%2Fn%3E%3Cs%3E4164%3C%2Fs%3E%3Cen%3E0%3C%2Fen%3E%3C%2Ftunedata%3E%0A
Oct 22, 2018 06:35:20.438 [6640] DEBUG - DVR:Grabber: Merging EPG item with live item.
Oct 22, 2018 06:35:20.441 [8716] DEBUG - Auth: authenticated user 1 as REDACTED
Oct 22, 2018 06:35:20.442 [9804] DEBUG - Request: [192.168.1.10:51339 (Subnet)] GET /status/sessions/background (8 live) TLS GZIP Signed-in Token (REDACTED)
Oct 22, 2018 06:35:20.444 [2004] DEBUG - Completed: [192.168.1.10:51339] 200 GET /status/sessions/background (8 live) TLS GZIP 2ms 470 bytes (pipelined: 5)
Oct 22, 2018 06:35:20.449 [6640] DEBUG - Added new metadata item (Live Session ypn4upsfv3qsw1wd5sjdefys) with ID 132717
Oct 22, 2018 06:35:20.449 [6640] DEBUG - Updating metadata item (save) (Live Session ypn4upsfv3qsw1wd5sjdefys) with ID 132717
Oct 22, 2018 06:35:20.449 [8336] DEBUG - HubCache: Expiring '1/home.ondeck/1/hubs/en-GB/count=16&excludeFields=summary&excludePlaylists=1&includeEmpty=1&includeFeaturedTags=1&includeStations=1&onlyTransient=1' because of event plex.event.item.created.
Oct 22, 2018 06:35:20.458 [6640] DEBUG - Updating part with ID=129410 []
Oct 22, 2018 06:35:20.458 [4584] DEBUG - DVR:Subscription: Waiting for media recorder to start.
Oct 22, 2018 06:35:20.458 [5360] INFO - Notification: Recording Live TV - Session -
Oct 22, 2018 06:35:20.458 [4584] DEBUG - DVR:Subscription: Rolling sub for channel 1 started successfully.
Oct 22, 2018 06:35:20.673 [8716] DEBUG - Completed: [192.168.1.10:51378] 200 POST /livetv/dvrs/6/channels/1/tune (8 live) TLS GZIP 5553ms 21114 bytes (pipelined: 8)
Oct 22, 2018 06:35:20.836 [8716] DEBUG - Auth: authenticated user 1 as REDACTED
Oct 22, 2018 06:35:20.836 [9804] DEBUG - Request: [192.168.1.10:51378 (Subnet)] GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flivetv%2Fsessions%2Fe076aec4-20e6-40e0-a412-66fff711f66a&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=0nj74cn12v7itipl54qys6fh&offset=0&subtitles=burn&copyts=0&Accept-Language=en-GB (8 live) TLS GZIP Signed-in Token (REDACTED)
Oct 22, 2018 06:35:20.836 [9804] DEBUG - Found session GUID of 0nj74cn12v7itipl54qys6fh in session start.
Oct 22, 2018 06:35:20.842 [9804] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Oct 22, 2018 06:35:20.842 [9804] DEBUG - Downloading document http://127.0.0.1:32400/livetv/sessions/e076aec4-20e6-40e0-a412-66fff711f66a?includeBandwidths=1&offset=0&X-Plex-Session-Identifier=ypn4upsfv3qsw1wd5sjdefys
Oct 22, 2018 06:35:20.843 [9804] DEBUG - Auth: authenticated user 1 as REDACTED
Oct 22, 2018 06:35:20.844 [9804] ERROR - MDE: video has neither a video stream nor an audio stream
Oct 22, 2018 06:35:20.844 [9804] DEBUG - MDE: received PLEX_PROTOCOL_ANY from client, but could not determine best protocol. Defaulting to HTTP
Oct 22, 2018 06:35:20.844 [9804] DEBUG - MDE: analyzing media item 128618
Oct 22, 2018 06:35:20.844 [9804] ERROR - Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Oct 22, 2018 06:35:20.847 [2004] DEBUG - Completed: [192.168.1.10:51378] 400 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flivetv%2Fsessions%2Fe076aec4-20e6-40e0-a412-66fff711f66a&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=0nj74cn12v7itipl54qys6fh&offset=0&subtitles=burn&copyts=0&Accept-Language=en-GB (8 live) TLS GZIP 10ms 457 bytes (pipelined: 9)
The Plex Tuner Service.log has only a single line that isn’t DEBUG or INFO and this can be found at Oct 22, 2018 06:35:22.023 :
Oct 22, 2018 06:35:15.314 [7080] INFO - [I] web_service_t::process_start_channel (device compound_device041dvb#bda#usb#vid_2040&pid_0265#0013973690#, channel triplet://9018:4164:4164)
Oct 22, 2018 06:35:15.314 [7080] INFO - [I] device_reactor_t::get_device_list (dvb#bda#usb#vid_2040&pid_0265#0013973690#)
Oct 22, 2018 06:35:15.314 [7080] INFO - [I] dvb_device_factory_t::get_device_list (dvb#bda#usb#vid_2040&pid_0265#0013973690#)
Oct 22, 2018 06:35:15.317 [4964] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBT Tuner]
Oct 22, 2018 06:35:15.317 [4964] INFO - [I] DeviceGetListEx_impl: device instance path usb#vid_2040&pid_0265#0013973690#
Oct 22, 2018 06:35:15.317 [4964] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBC Tuner 2]
Oct 22, 2018 06:35:15.317 [4964] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBC Tuner]
Oct 22, 2018 06:35:15.317 [4964] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBT Tuner 2]
Oct 22, 2018 06:35:15.317 [4964] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{7c8095ab-c110-40e5-9f4d-310858bbbf64}, Name Hauppauge WinTV-dualHD DVBT Tuner, Standards 1
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{5fd033f5-8c4d-4de2-b4f2-e3d728a696e5}, Name Hauppauge WinTV-dualHD DVBC Tuner 2, Standards 2
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{b50b8116-da24-4f97-80d1-00451702c5f7}, Name Hauppauge WinTV-dualHD DVBC Tuner, Standards 2
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}, Name Hauppauge WinTV-dualHD DVBT Tuner 2, Standards 1
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-dualHD DVBT Tuner, id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{7c8095ab-c110-40e5-9f4d-310858bbbf64}, tuners 1, state 0, standards 1
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-dualHD DVBC Tuner 2, id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{5fd033f5-8c4d-4de2-b4f2-e3d728a696e5}, tuners 1, state 0, standards 2
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-dualHD DVBC Tuner, id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{b50b8116-da24-4f97-80d1-00451702c5f7}, tuners 1, state 0, standards 2
Oct 22, 2018 06:35:15.318 [7080] INFO - [I] device_manager_t::get_device_list. Device Hauppauge WinTV-dualHD DVBT Tuner 2, id dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}, tuners 1, state 0, standards 1
Oct 22, 2018 06:35:15.320 [7080] INFO - [I] device_manager_t::add_streamer. Channel triplet://9018:4164:4164, device dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}, streamer id 64e8470c-0027-4904-bc7f-68dfb4ac0fdf
Oct 22, 2018 06:35:15.320 [7080] INFO - [I] device_reactor_t::create_device dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Oct 22, 2018 06:35:15.322 [1436] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBT Tuner]
Oct 22, 2018 06:35:15.322 [1436] INFO - [I] DeviceGetListEx_impl: device instance path usb#vid_2040&pid_0265#0013973690#
Oct 22, 2018 06:35:15.322 [1436] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBC Tuner 2]
Oct 22, 2018 06:35:15.322 [1436] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBC Tuner]
Oct 22, 2018 06:35:15.323 [1436] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBT Tuner 2]
Oct 22, 2018 06:35:15.323 [1436] INFO - [I] DeviceGetListEx_impl: device instance path usb#vid_2040&pid_0265#0013973690#
Oct 22, 2018 06:35:15.323 [1436] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Oct 22, 2018 06:35:15.323 [7080] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://9018:4164:4164 on device device dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}.
Oct 22, 2018 06:35:15.324 [7080] INFO - [I] transponder_streamer::start_idle_timer
Oct 22, 2018 06:35:15.324 [7080] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 9018, tid 4164, sid 4164
Oct 22, 2018 06:35:15.324 [7000] INFO - [I] streamer_container_t::control_thread. Added streamer 64e8470c-0027-4904-bc7f-68dfb4ac0fdf
Oct 22, 2018 06:35:15.324 [7000] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Oct 22, 2018 06:35:15.324 [7000] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://9018:4164:4164
Oct 22, 2018 06:35:15.324 [7000] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://9018:4164:4164
Oct 22, 2018 06:35:15.324 [7000] INFO - [I] transponder_streamer::stop_idle_timer
Oct 22, 2018 06:35:15.377 [1888] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBT Tuner]
Oct 22, 2018 06:35:15.377 [1888] INFO - [I] DeviceGetListEx_impl: device instance path usb#vid_2040&pid_0265#0013973690#
Oct 22, 2018 06:35:15.377 [1888] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBC Tuner 2]
Oct 22, 2018 06:35:15.377 [1888] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBC Tuner]
Oct 22, 2018 06:35:15.377 [1888] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-dualHD DVBT Tuner 2]
Oct 22, 2018 06:35:15.378 [1888] INFO - [I] DeviceGetListEx_impl: pDL->Count:4
Oct 22, 2018 06:35:15.378 [1888] INFO - [I] find_device_by_path. searching for matching tuner with device path @device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Oct 22, 2018 06:35:15.378 [1888] INFO - [I] find_device_by_path. Found device index 3 for device path @device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Oct 22, 2018 06:35:15.378 [1888] INFO - [I] StartDevice()  dwDeviceNo:3
Oct 22, 2018 06:35:15.386 [1888] INFO - [I] BDA Device Name: [Hauppauge WinTV-dualHD DVBT Tuner 2]
Oct 22, 2018 06:35:15.389 [1888] INFO - [I] add_filter (Hauppauge WinTV-dualHD DVBT Tuner 2)
Oct 22, 2018 06:35:15.389 [1888] INFO - [I] Tuner identity: vid (2040), pid (0265), subsys ()
Oct 22, 2018 06:35:15.389 [1888] INFO - [I] ret_val: 0
Oct 22, 2018 06:35:15.405 [1888] INFO - [I] add_filter (Microsoft DVBT Network Provider)
Oct 22, 2018 06:35:15.410 [1888] INFO - [I] TuningSpace Name: 'Antenna'  NetworkType: {00000000-0000-0000-0000-000000000000}
Oct 22, 2018 06:35:15.410 [1888] INFO - [I] TuningSpace Name: 'ATSC'  NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Oct 22, 2018 06:35:15.410 [1888] INFO - [I] TuningSpace Name: 'ATSCCable'  NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Oct 22, 2018 06:35:15.410 [1888] INFO - [I] TuningSpace Name: 'AuxIn1'  NetworkType: {00000000-0000-0000-0000-000000000000}
Oct 22, 2018 06:35:15.411 [1888] INFO - [I] TuningSpace Name: 'Cable'  NetworkType: {00000000-0000-0000-0000-000000000000}
Oct 22, 2018 06:35:15.411 [1888] INFO - [I] TuningSpace Name: 'DD2 DVB-T'  NetworkType: {216C62DF-6D7F-4E9A-8571-05F14EDB766A}
Oct 22, 2018 06:35:15.411 [1888] INFO - [I] Enumeration found 6 tuning spaces
Oct 22, 2018 06:35:15.411 [1888] INFO - [I] Found TuningSpace
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces: Pin types (2) :
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:		Pin 0 Type = Input
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:		Pin 1 Type = Output
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces: Node types (2):
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:		Node 0 Type = 0
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:		Node 1 Type = 1
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces: Node interfaces:
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:    Interfaces on NodeType 0   (2 interfaces):
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:       {71985F47-1CA1-11D3-9CC8-00C04F7971E0} IID_IBDA_FrequencyFilter
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:       {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
Oct 22, 2018 06:35:15.413 [1888] INFO - [I] GetTunerInterfaces:    Interfaces on NodeType 1   (3 interfaces):
Oct 22, 2018 06:35:15.414 [1888] INFO - [I] GetTunerInterfaces: {DDF15B12-BD25-11D2-9CA0-00C04F7971E0} IID_IBDA_AutoDemodulate     - QueryInterface FAILED ! - hr = 0x80004002
Oct 22, 2018 06:35:15.414 [1888] INFO - [I] GetTunerInterfaces:       {1347D106-CF3A-428A-A5CB-AC0D9A2A4338} IID_IBDA_SignalStatistics
Oct 22, 2018 06:35:15.414 [1888] INFO - [I] GetTunerInterfaces:       {EF30F379-985B-4D10-B640-A79D5E04E1E0} IID_IBDA_DigitalDemodulator
Oct 22, 2018 06:35:15.414 [1888] INFO - [I] Looking for preferred capture for tuner @device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9}
Oct 22, 2018 06:35:15.414 [1888] INFO - [I] Found preferred capture: @device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{fd0a5af4-b41d-11d2-9c95-00c04f7971e0}\{bc102acb-6095-451d-8ed6-16cf3c832ebc}
Oct 22, 2018 06:35:15.431 [1888] INFO - [I] add_filter (Hauppauge WinTV-dualHD TS Capture)
Oct 22, 2018 06:35:15.434 [1888] INFO - [I] add_filter (Sample grabber)
Oct 22, 2018 06:35:15.437 [1888] INFO - [I] add_filter (MPEG-2 Demultiplexer)
Oct 22, 2018 06:35:15.440 [1888] INFO - [I] add_filter (BDA MPEG2 Transport Information Filter)
Oct 22, 2018 06:35:20.553 [1888] INFO - [I] start_graph: hr=0, state=2
Oct 22, 2018 06:35:20.553 [1888] INFO - [I] StartDevice()    OK
Oct 22, 2018 06:35:20.553 [1888] INFO - [I] ----------------------------------------------------------------------------
Oct 22, 2018 06:35:20.553 [1888] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 489833, modulation 0, polarization 0, symbol rate 0, LOF 8, LNB selection signal 0, FEC 0
Oct 22, 2018 06:35:20.553 [1888] INFO - [I] SetTuner() 489833, H, 0  Mod:0 LOF:8  22Khz:0
Oct 22, 2018 06:35:21.366 [7000] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 58, 79, 1
Oct 22, 2018 06:35:21.366 [6320] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://9018:4164:4164
Oct 22, 2018 06:35:21.366 [6320] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT...
Oct 22, 2018 06:35:21.377 [4284] INFO - [I] http_streamer_t::send_thread_func: adding http client
Oct 22, 2018 06:35:21.417 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.447 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.639 [1888] DEBUG - [I] required sid 4164
Oct 22, 2018 06:35:21.639 [1888] DEBUG - [I] services (25): 4164,
Oct 22, 2018 06:35:21.639 [1888] DEBUG - [I] pmt pid found: 100
Oct 22, 2018 06:35:21.649 [6320] INFO - [I] tvs_program_streamer::tuning_thread. Waiting for PMT...
Oct 22, 2018 06:35:21.690 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 100, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.790 [6320] INFO - [I] tvs_program_streamer::tuning_thread. PAT and PMT found. Checking CA descriptors
Oct 22, 2018 06:35:21.841 [6320] INFO - [I] tvs_program_streamer::tuning_thread. Start streaming
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 101, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 102, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 106, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 105, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 152, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 7201, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 7219, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 7103, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 7105, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 16, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 17, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 18, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.852 [1888] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 8191, client triplet://9018:4164:4164
Oct 22, 2018 06:35:21.905 [6320] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://9018:4164:4164
Oct 22, 2018 06:35:21.959 [1888] INFO - [I] CTSStreamWaiter::GetPidToCheck. PID to check 101
Oct 22, 2018 06:35:21.959 [1888] INFO - [I] CTSStreamWaiter::GetVideoPid. Video PID 101
Oct 22, 2018 06:35:21.991 [1888] INFO - [I] CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streaming
Oct 22, 2018 06:35:22.023 [7080] WARN - [E] http_streamer_t: http write error
Oct 22, 2018 06:35:22.024 [4284] INFO - [I] http_streamer_t::send_thread_func: removing http client
Oct 22, 2018 06:35:22.024 [4284] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Oct 22, 2018 06:35:22.025 [7000] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer 64e8470c-0027-4904-bc7f-68dfb4ac0fdf
Oct 22, 2018 06:35:22.027 [7000] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Oct 22, 2018 06:35:22.027 [7000] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://9018:4164:4164
Oct 22, 2018 06:35:22.027 [7000] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://9018:4164:4164
Oct 22, 2018 06:35:22.039 [1888] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://9018:4164:4164
Oct 22, 2018 06:35:22.039 [7000] INFO - [I] transponder_streamer::start_idle_timer
Oct 22, 2018 06:35:26.401 [3248] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://9018:4164:4164 on device dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9} is idle. Deleting it.
Oct 22, 2018 06:35:31.341 [10816] INFO - [I] Stopping graph
Oct 22, 2018 06:35:31.368 [1888] INFO - [I] StopDevice()
Oct 22, 2018 06:35:31.639 [1888] INFO - [I] stop_graph: hr=0, state=0
Oct 22, 2018 06:35:36.425 [3248] INFO - [I] device_manager_t::idle_timer_func. Device dvb#bda#0#@device:pnp:\\?\usb#vid_2040&pid_0265#0013973690#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{510162d9-2f7e-49e7-907b-dbd3a5a15eb9} is idle. Unloading it.
Oct 22, 2018 06:35:36.425 [3248] INFO - [I] transponder_streamer::stop_idle_timer
Oct 22, 2018 06:35:36.425 [3248] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Oct 22, 2018 06:35:36.427 [3248] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Oct 22, 2018 06:35:36.427 [3248] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Oct 22, 2018 06:35:36.644 [10816] INFO - [I] transponder_streamer::idle_thread_func finished
That the WARN is a:
Suggests to me it’s file permissions of the destination write endpoint. But it’s not obvious to me how to resolve that (i.e. is it a directory on the Media Server? what should the permissions be? etc)
I attempted to capture errors similar to yours to see if we could come up with a smoking gun and came up empty. I have some errors related to the web client closing the connection but nothing indicating a server or tuner error.
Interestingly, if I scan channels on the DVR panel, I am then able to view a stream immediately after. The next day it tends to stop working again.
Hi, I have exactly the same problem with a Wintv dual HD on my Nvidia Shield, work great just after a scan, and then error S1001 network…
I just checked if I can tune and it seems to be working on the first channel I tried then failed on the rest. No idea what’s going on.
Hello there. Any news ?
Mine is sometime working, sometime completely broken, impossible to see a channel…
Sorry no, tho I do see a pending PLEX server update on the beta channel I need to get around to installing.
I really love Plex, but there’s no way to contact the tech support for problems like this… it’s a pity !
I bought plex pass, shield and wintv dual like they said, everything should work together ! hope they release a new server version that will correct the bug.
Have a nice day
Out of curiosity, are either of you running Plex as a service like me?
I noticed today that if I stop the service and run it directly, the Hauppage starts working fine in Plex. I tested it three times and each time was the same result of “Error s1001 (Network)” or works fine when started directly.
The account the service runs as is an administrator so I’m not sure how that could play into a rights issue but it does seem repeatable for me.
It still wont find any channels…
