HDHomerun Plex Server not allowing streaming
Server Version#: Newest
Player Version#: Variety
Tuner Make/Model: HDHomerun Flex 4k HDFX-4K
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I have audio files that will stream just fine and the guide for my channels tuned from the HDHomerun’s acquired stations show up but currently do not stream and have not streamed properly for some time. Occasionally an update would come out and it would briefly work.
Plex Media Server Logs_2022-03-19_10-28-21.zip (3.4 MB)
I’m sorry if I didn’t provide enough information but could someone help guide me into figuring out why this only works sporadically? Is it because of the HDHomerun updates or is there a very specific server config that I need. I’ve tried a variety of settings but right now the only way for me to connect seems to be through proxy even though the plex server says everything is properly set up and accessible. Please assist, I’d be incredibly grateful as I need these stations to be accessible remotely.
Edit: Connection through proxy is not working now either.
Plex doesn’t currently work with any 4K channels, you need to disable them in the guide.
What proxy are you talking about?
