[HELP] Setup Plexconnect on a dedicate Server ?
Hello all,
I have plan to rent a dedicate server (windows server) and host plex and plexconnect.
As a dedicate server they will give you one static ip so i have to setup anything else so the plexconnect will work remotely ?
I have on local pc plex and plexconnect and its working perfect but i dont know if i have to change anything so it will work directly from a dedicate server.
Anyone has any idea ?
Thank you.
Are you planning to set this up in a data centre?
What is the reason for doing this instead of running it from home?
Bandwidth usage could become very expensive very quickly.
Yes in a datacenter.
Not so much i7 16gb ram 6tb unmetered 100mb/s approximately 125euro per month
Because i want to stream it to my family and friends : 5-6 people.
It is possible to configure it to work, but it is unsupported and at the moment you would share a watched status.
We would hope that full MyPlex support will be ready soon (almost all development effort is currently focused on getting a good implementation of this) and then remote access would be supported, along with proper multi user support.
I would wait a week or two to pull the trigger :wink:
Thanks f00b4r that would be great
So the time isnt yet !! … But sooon :slight_smile:
Now that myplex should work any idea how is this possible to work with a dedicate server;
Thanks.
I am not sure you would need anything special apart from:
  • ensure that the MyPlex port is open
  • ensure the right version of Python is installed
  • ensure you make any necessary configuration changes for a server OS (there are plenty of threads for each OS)
Oops just read you wanted to host PlexConnect there as well.
You will have to make some extra changes for that - there are a cpl of threads where people have set this up at a remote location.
The best thing to do is probably test with it setup at e.g. a friends house.
F00b4r : i have made a test to see how to work this but i wasnt successfull.
From my home internet i open all the port from router so it can redirect to the plex server ( 53,80,443).
I went to my sister and i could connect to my plex server through web or for an android tv.
Then i put the apple tv and changed the dns to my static isp ip (home plex server) but apple tv was saying no trailer.
But maybe its different in a dedicate server that has its own ip than from my home ip that using an isp;
Here is the log. It show that it is connected but apple tv is saying trailer is unavailable
19:48:00 PlexConnect: started: 19:48:00
19:48:00 Settings: getsetting enable_plexconnect_autodetect=true
19:48:00 Settings: getsetting ip_plexconnect=192.168.1.5
19:48:00 PlexConnect: IP_self (from settings): 192.168.1.5
19:48:00 Settings: getsetting enable_dnsserver=True
19:48:00 DNSServer: started: 19:48:00
19:48:00 Settings: getsetting port_dnsserver=53
19:48:00 Settings: getsetting ip_dnsmaster=8.8.8.8
19:48:00 Settings: getsetting prevent_atv_update=True
19:48:00 DNSServer: ***
19:48:00 DNSServer: DNSServer: Serving DNS on 192.168.1.5 port 53.
19:48:00 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.5
19:48:00 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:48:00 DNSServer: forward other to higher level DNS: 8.8.8.8
19:48:00 WebServer: started: 19:48:00
19:48:00 Settings: getsetting port_webserver=80
19:48:00 Settings: getsetting enable_webserver_ssl=True
19:48:00 WebServer: ***
19:48:00 WebServer: WebServer: Serving HTTP on 192.168.1.5 port 80.
19:48:00 ATVSettings: init class CATVSettings
19:48:00 ATVSettings: load settings
19:48:00 Settings: getsetting port_ssl=443
19:48:00 Settings: getsetting certfile=./assets/certificates/trailers.pem
19:48:00 WebServer: WebServer: Serving HTTPS on 192.168.1.5 port 443.
19:48:29 DNSServer: DNS request received!
19:48:29 DNSServer: Source: ('5.203.29.25', 47734)
19:48:29 DNSServer: Domain: trailers.apple.com
19:48:29 DNSServer: ***intercept request
19:48:29 DNSServer: -> DNS response: 192.168.1.5
19:48:31 DNSServer: DNS request received!
19:48:31 DNSServer: Source: ('5.203.29.25', 47734)
19:48:31 DNSServer: Domain: trailers.apple.com
19:48:31 DNSServer: ***intercept request
19:48:31 DNSServer: -> DNS response: 192.168.1.5
You might want to give a better detailed overview of your setup including IP addresses etc.
The above shows you using local IP addressing, this will mean nothing to machines away from your LAN.
I run my Plex server also dedicated - it's a lot of effort if you want to lock the system from the outside - with MyPlex everything is now simple - best lock on the server all ports and release individually - and the port for the DNS to Apple TV I would release only via firewall addresses to static IP addresses or via script on DynDNS.. ;-)
Without MyPlex you had to share in addition to a cron job or daemon IP addresses from DynDNS..
