Help with newest PMS upgrade or downgrade to my previous version
I would like to downgrade to my previous PMS Version or one that will not give me an error.
Does it take a more powerful Internet to run these newer versions of PLEX?
I just ran an AT&T Internet Speed Test (January 17, 2018 at 5:38 PM) and got download 14.82Mbps and upload 1.58Mbps
I have a Synology DS415+ with the most recent DSM update (6.1.4-15217 Update 5) 64 bit compatible
Plex Media Server with PLEX’s most recent update (Version 1.11.0.4666)
Vizio 70” E70 E3 TV with PLEX app
Xbox one: as a backup PLEX app, since television companies think it’s acceptable to remove apps that came with the TV that you purchased and then remove these apps later.
I usually don’t mess with updates and this is why…
Since the most recent PLEX update every movie I start (MOVIES DO START AND PLAY) eventually pauses with the loading symbol in the center of the screen and then says…
There was a problem playing this item.
An unexpected error occurred while downloading the media.
Go Back
I get the same problem on both the Vizio television and on the Xbox one.
Whether I go back and resume from where I was or restart the movie it does the same thing.
I would like to go back to the version of PLEX that I was NOT having any problems with which was 1.5.3.3580-4b377d295. Searching this forum I have found where to find a copy of this version that my iMac keeps in a folder
(Macintosh HD>Users>Home>Library>Application Support>Plex Media Server>Updates)
But I have not been able to get it to install on the DS.
When I compress it it is given a zip file extension which I tried after trying to give it a spk file extension. With all my attempts with various prefixes all of my attempts at a manual install on my Disk Station say invalid format.
This Plex post says my disc station is 64 bit compatible
64 bit compatible Synology DiskStation models
ChuckPA: April 26 edited April 26 in Synology
https://forums.plex.tv/discussion/269113/64-bit-compatible-synology-diskstation-models
I also found these 2 links while searching the forums but I’m not sure which if any one is for the Synology DS415+.
It is an index of version 1.5.3.3580-4b377d295
(Index of /download/Package/spk/Plex Media Server/1.5.3.3580-4b377d295)
Is someone able to tell me if one of these is correct? And if someone is able to will you? Please
Different links but same information and downloadable Versions of PLEX.
https://archive.synology.com/download/Package/spk/Plex%20Media%20Server/1.5.3.3580-4b377d295/
https://usdl.synology.com/download/Package/spk/Plex%20Media%20Server/1.5.3.3580-4b377d295/
I also tried this and was obviously unsuccessful because I am still posting this
HOW TO DOWNLOAD PREVIOUS PLEX VERSION
https://www.google.com/search?q=HOWTO+DOWNLOAD+PREVIOUS+PLEX+VERSION&ie=utf-8&oe=utf-8&client=firefox-b-1
If you need anymore information from me let me know and I will try and be as helpful as I can.
Go easy on me it’s my first post. Just kidding, give it to me, I can take it. Haha.
I love PLEX! I’ve been using it for years. First streaming through my computer to TV and now through my Synology Disk Station to TV. I would love to be running the most recent updates and give this cord cutting a chance.
You can download PMS 1.10.1 from the Public download point at downloads.plex.tv .
Most of us keep our older SPK files (at least a few) in case something goes wrong. Did you and perhaps forget where you put them?
I did not have any older SPK files to keep. When I got the disk station I downloaded PLEX from the Synology disk station and I never upgraded until just recently.
I take that back I do have older ones from my iMac but that won’t work on the synology, correct?
correct. iMac is a different packaging plus the binaries themselves are different (Unix vs Linux)
Best you can get is 1.10.1 from plex.tv (always best anyway. Synology doesn’t distribute the 64 bit package anymore for some reason)
Thank you very much for such easy to follow guide. I downgraded in no time without any problems
