HEVC 10 bits files, player crash
Hi
I have a QNAP hosting the server and I use clients on android and win10 x64
HEVC 10 bits files just make the player crash
Strange thing: I’ve experienced the same behavior with 2 different pentium7 machines
No problem with another machine with another processor.
I’ve dug in the logs and could only find this
Mar 16, 2022 23:28:10.854 [0x7f9a06cacb38] DEBUG - Content-Length of /share/CACHEDEV1_DATA/Multimedia/Animes/Utawarerumono The False Faces (2015)/Utawarerumono The False Faces (2015) - 01x01 - Curse.mkv is 16125 (of total: 411236109).
Mar 16, 2022 23:28:10.868 [0x7f9a070adb38] DEBUG - Failed to stream media, client probably disconnected after 3407872 bytes: 104 - Connection reset by peer
Mar 16, 2022 23:28:10.868 [0x7f9a070adb38] DEBUG - Completed after connection close: [192.168.30.201:64660] 206 GET /library/parts/53944/1443956400/file.mkv?Accept-Language=fr (11 live) TLS 414ms 3407872 bytes (range: bytes=0-)
Mar 16, 2022 23:28:10.872 [0x7f9a070adb38] DEBUG - Completed: [192.168.30.201:64661] 206 GET /library/parts/53944/1443956400/file.mkv?Accept-Language=fr (10 live) TLS 23ms 16125 bytes (range: bytes=411219984-)
Mar 16, 2022 23:28:10.939 [0x7f9a0698eb38] DEBUG - Request: [192.168.30.201:64662 (Subnet)] GET /library/parts/53944/1443956400/file.mkv?Accept-Language=fr (11 live) TLS Signed-in Token (JYL-JYL) (L1) (range: bytes=2900117-)
Mar 16, 2022 23:28:10.942 [0x7f9a0698eb38] DEBUG - Content-Length of /share/CACHEDEV1_DATA/Multimedia/Animes/Utawarerumono The False Faces (2015)/Utawarerumono The False Faces (2015) - 01x01 - Curse.mkv is 408335992 (of total: 411236109).
Mar 16, 2022 23:28:12.461 [0x7f9a060ffb38] DEBUG - BPQ: deferring onLibraryChanged callback, only 3 seconds since last library change
Mar 16, 2022 23:28:15.093 [0x7f9a070adb38] DEBUG - Failed to stream media, client probably disconnected after 35717120 bytes: 104 - Connection reset by peer
Mar 16, 2022 23:28:15.093 [0x7f9a070adb38] DEBUG - Completed after connection close: [192.168.30.201:64662] 206 GET /library/parts/53944/1443956400/file.mkv?Accept-Language=fr (10 live) TLS 4154ms 35717120 bytes (range: bytes=2900117-)
Mar 16, 2022 23:28:15.213 [0x7f9a0708ab38] DEBUG - handleStreamRead code 104: Connection reset by peer
Mar 16, 2022 23:28:15.213 [0x7f9a0708ab38] DEBUG - NotificationStream: Removing because of error
