Hide recommendations
Hi is it possible to hide the Recommendations Tap at the start? I would like the Library mode to be used as a default mode.
Enable “Remember selected tab” in the preferences of your client(s).
Switch to the “Library” tab.
In the case of the web app, tell your web browser to NOT delete the cookies of plex.tv when it’s closed. Otherwise all client settings will revert to the default.
Adding to Otto’s point on how you can already deal with this… there’s already an existing feature suggestion discussing an option to hide/remove the recommendations tab for good. If the above isn’t doing it for you, please comment/vote in that thread in order to help us avoid distracting or cannibalizing votes.
