High CPU usage
Hello everyone, I have a question, is it normal that when I open the Plex application on my Apple TV, for example, the CPU increases? On some occasions it takes a long time to load only the home page, sometimes I have to exit and enter the plex application and reopen it so that the home page loads, also when browsing between lists it goes up and then when loading the series or metadata of the file stabilizes, it’s not really a big deal but I don’t remember that happening before the last update, could this be a bug? Does it happen to anyone else? I would like to know your opinion, thank you.
Server Version#: 1.32.8.7639
Player Version#: 4.116.1
Linux version: 20.04.6 LTS (Focal Fossa)
Processor: AMD EPYC 7282 S-SP3 2.80GHz 16-Core
On this occasion it took more than 2 minutes to load and on my Apple TV I had to close the application, when I opened it again the server appeared offline and after approximately 50 seconds it returned and started normal again.
sounds like you need some DB cleanup
I already do it a couple of days ago and this was the result:
Automatic Check,Repair,Index started.
Checking the PMS databases
Check complete. PMS main database is OK.
Check complete. PMS blobs database is OK.
Exporting current databases using timestamp: 2024-02-01_10.57.34
Exporting Main DB
Exporting Blobs DB
Successfully exported the main and blobs databases. Proceeding to import into new databases.
Importing Main DB.
Importing Blobs DB.
Successfully imported databases.
Verifying databases integrity after importing.
Verification complete. PMS main database is OK.
Verification complete. PMS blobs database is OK.
Saving current databases with ‘-BACKUP-2024-02-01_10.57.34’
Making repaired databases active
Repair complete. Please check your library settings and contents for completeness.
Recommend: Scan Files and Refresh all metadata for each library section.
Backing up of databases
Backup current databases with ‘-BACKUP-2024-02-01_11.03.28’ timestamp.
Reindexing main database
Reindexing main database successful.
Reindexing blobs database
Reindexing blobs database successful.
Reindex complete.
Automatic Check, Repair/optimize, & Index successful.
But please help me with this:
When I finished I went to “Library” and I just clicked on “Scan Library Files”, and I also manually have to click on “Refresh All Metadata” for each list or is that not necessary?
going to need your server DEBUG logs ZIP which captures the start of that playback (or recreation thereof)
Don’t know why the spike off the top of my head but the DEBUG logs should show it.
