Server Version#:1.15.1.710
Player Version#:3.13.13
Since today (27/02/18) I am unable to use the plex app on my smart tv. I was using it 2 days ago but today it took ages to load then when navigating to some shows the app reports the media is missing. I did manage to get an episode start playing but it also keeps stopping then reporting the media is missing.
My android, ios and xbox one apps all work fine.
Did something change server side in an update that would cause the Hisense app to fail?
There was a server update recently, another today. (Beta channel) so im guessing whatever changed server side broke the version Hisense use. Its definitely just that player, I have a lot of devices and I have tried them all, Xbox one, mac, windows 10, iphone, ipad, amazon fire tv, even crappy chinese android box (without DTS) all navigate fine through sections (very slow on Hisense) and then all devices play fine, apart from Hisense which sometimes starts to play a file then says file is missing, doesnāt even play, just sits with 3 horizontal dots or finally locks up on the menu before I can even play a thing.
Weāre able to play here but resuming from previous position no longer works. We also have the issue of the play/pause/fast forward/rewind buttons not working and just pulling the options up.
Same for me, everytime i try with the hisense app , iāve got the error screen with the dog. I try to re-associate the tv and the plex sever (https://plex.tv/link), but still same issue
I too am having problems with the same version of Plex for Hisense. I find that I have to enable all the audio tick boxes in Settings under Audio and I change the Video to 4.2 (I believe BluRay H264 default is 4.1 anyway) and if youāre set to 4.0, itāll transcode regardless. Push it to 5.0 and I just start getting crashes left, right and centre.
Most of the movies I have I just use the built in āMediaā app and search via DLNA for the Plex Server and usually Direct Plays both video and audio.
I have given up hope of a fix. It must be something Hisense are doing, a few days afterwards there was a firmware update for the TV. It changed the store part a little, updated the logoās of a few apps. It also REMOVED smartiptv from their store which I also used. I have now switched to using plex on my xbox one. Its simply brilliant. If you have one give it a try. Full HEVC playback, 4k looks ok too. Pretty much everything I play direct streams, and passes the DTS/DTS-HD audio to my Onkyo amp.
Same here, hasnāt worked properly in a few months. Started with a few files stopping at the beginning but could ātrickā it by getting past about 60s on another device then playing on the TV.
Now, nothing is playing (well, about 1s worth) before going back to home screen and tricking it only results in about 30s of playback before it stops.
Iāll be cancelling my Plex subscription if this isnāt/canāt be resolved soon as itās the only device I use.
Same issue here.
Hisense H50AE6000 with 3.13.13 Plex App.
App stops responding when starting to play any movie.
Hitting exit plays the sound of the TV again but atill Plex UI - so powering off the TV only helps.
