How do i add a TV Show to add Metadata?
sorry if it has been asked before
It seems that the show "Time Warp" has no information about it.
how do i go about adding this information?
Ensure you are naming your media correctly so that Plex can identify it and download the metadata automatically -> http://wiki.plexapp.com/index.php/Media_Naming_and_Organization_Guide
Thanks for that,
yes i checked, it was the first thing i did
this is one for a show that is correctly shown, and all my TV shows are in a format similar
The.Mentalist.S04E08.HDTV.XviD-ASAP.[VTV].avi
this is the format for the non-metadata TV show, and the file number changes per episode. there are 19 episodes.
Time.Warp.S01E01.720p.HDTV.x264-DON.mkv
Is this the series you're talking about?
http://thetvdb.com/?tab=series&id=82682&lid=7
I ask because it has more than 19 episodes. Meanwhile, you might try going into the media manager and trying to fix an incorrect match on the series. It may be that something isn't being fed to TVDB right or something is causing TVDB to fail to find the series. Try the link below. Your mileage may vary depending on your server OS.
http://wiki.plexapp.com/index.php/PlexNine_PMS_MediaManager#Fix_Incorrect_Match
