I’m trying to catalog a movie that spills onto 2 DVD disks. The PLEX database correctly identifies and presents metadata for the first file, but it mis-classifies the second file as another different title. Can someone clarify the process to include 2 .m4v in a single metadata package?
This article describes it in detail. But the short version is that the files should be named identically, save for a suffix identifying the disc/part number for each.
See “Movies Split Across Multiple Files” section.
However, you’ll be much better served by combining the two files into one movie. Plex handles that much better.
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/#toc-2
I see no point in jumping through hoops or changing naming to solve this kind of problem.
My solution is to rip each DVD separately and then I use any of a number of tools to join the two files together (I usually use “FreeMake” but that is mainly because I am used to it) and name the result as “MovieName (year).ext”.
By doing it that way I avoid all the problems and issues that the “two file” system produces. I keep all my naming as simple as possible and that way I only rarely have any recognition problems and, when I do have problems, it is usually due to the movie or film being rather old or obscure or both. I have several movies I have used this technique on and they all work fine.
