So A couple of my Movies that are ripped from DVD are too long to fit on a single DVD, so the movie is split either on to a double sided DVD or two separate DVDs. This means two separate files for one movie. Example: dances with wolves.
I would like to keep both parts in one folder, but this presents two problems for me
The named files (Side a & b) don’t load in any Meta Data
I haven’t been able to figure out any way to play the second part, including making a playlist out of the two separate files.
Is there any way that I can keep both files in the same folder, so that it will go under one name, that will retrieve the metadata properly so I don’t have to type it in myself and will play both files consecutively?
