How Do You Merge Folders/Libraries?
I uploaded my movie files and it put the movies into 4 different libraries all called “movies”. Some of which only put like 5 movies in one folder. How do I merge these. I only want one file called “Movies” that’s it but when I go to edit there’s no option to merge or even drag movies into another folder
I assume you are talking about “libraries”, not “folders”.
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
I’m looking to merge libraries of movies that are already uploaded into my server though. This link only explains how to organize your movies on your computer before uploading. I uploaded them all at the same time under the movie category but for some reason, it created 4 movie libraries instead of just 1.
You don’t “upload” movies to Plex. You merely “point” Plex to the files, from where it will read them when they are requested by a Plex client app.
You will need to reorganise those folders and then remove 3 of the libraries from Plex.
Then edit the remaining library and point it to the “parent folder” where all your movies are collected.
