Mergin 2 libraries named the same but on different external device
Server Version#:
I control my PLEX libraries with a PC. I have 2 external HDD holding my media with a folder named Movies on each. Both are added into PLEX under the same name but they are not merged. Meaning that both libraries are not combined and I need to get out of one and get into the other one to have access to the other half. I do not recall having to do that, I believe it has to do with a PLEX update or maybe I am doing something wrong. Please help.
You can add both Movie folders to one library.
Edit one of the libraries and add the Movies folder that isn’t already there.
If you have two libraries you must have created them. Plex doesn’t do that on it’s own.
Case solved. Thank you.
