How on earth do I 'Disable Emptying of Trash'?
After 7 + google searches and reading the links below, I am embarrassingly having to post this incredibly simple question on the forum:
How to I disable emptying of trash?
I have looked in all the Plex apps and settings with no luck at all. Following the instructions for any of the links below doesn’t make any sense. Apparently I am meant to ‘Open Plex Web App’ but I don’t have this. I have these:
Screenshot 2020-03-08 23.26.48
Why are there no instructions for the other apps?
https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
https://support.plex.tv/articles/200289526-library/
https://support.plex.tv/articles/200289326-emptying-library-trash/
Server Version#: Version 1.18.7.2457-77cb9455c
Player Version#: Don’t even know how to find out - there is no ‘about’ section in the app
It’s described in the Emptying Library Trash support article you have linked in your post…
The setting you’re looking for is in Settings > Server > Library… go there and uncheck Empty trash automatically after every scan
Thanks very much - found it! Don’t know why it wasn’t easier. Solved :slight_smile:
