How to connect an external drive which is connected to WDMYCLOUD to the library?
Server Version#: 4.34.4
I am totally new to Plex.
I have installed it and run in on a NVIDIA SHIELD PRO 2017.
In my network I have a WD MYCLOUD external drive on which I keep my movies.
I have this MYCLOUD drive connected to PLEX so all the movies on that drive are visible in PLEX.
But now I have connected another external drive to the usb-port of the WD MYCLOUD on which I keep music-movies. But PLEX can’t access that drive. It only shows me the WD MYCOULD disk.
How can I add the movies which are on the other external drive to my PLEX library?
You need to go into the WD configuration page and mount the usb drive. The name you give it will then appear as another folder from the NAS.
