How to create restrictions
Hello Everyone,
I want to have say 2 copies of a Movie, HD and UHD, but restrict users from seeing the UHD Movies, plus I (being admin) want to see the HD version and if there’s a UHD version not the HD just the UHD version.
I’ve tried Labels and Merging but it does not give me the required results. Is it possible?
TIA
You may need to separate them out into their own library. I dont think there is a way to apply restrictions on an edition
I can but that still gives me two versions of the one Movie, the HD and UHD. When there is two versions I just want to see the UHD one.
There’s no way to do the combination of things you’re describing.
Thank you for your reply. I thought as much. :smiley:
You can by clicking on the pencell on said video and you will see sharing label name it say Restricted then click the lock then go to said user that you want to block under Plex Home or Mange Library Access and set Restrictions using the label name you created
Doing that will only block that said video from that said user unless you set those same restrictions under each user
