How to fix Incorrect TV DVR Match?
I’ve been using the DVR to record the latest series of The Apprentice in UK from Freeview (antenna). It automatically names the folder for this TV series as “The Apprentice (2015)” based on the EPG. However it keeps matching it to The Apprentice (IE) (in Ireland). It looks like both these shows started in 2015, so the year isn’t helping here. I fix the match to “The Apprentice (UK)” but then it goes back to IE the next week once I’v watched (and it’s auto-deleted) the previous episode. Usually to fix these things I’d put in the country in the folder name, but as this folder is created by the EPG, I can’t change the folder name here. any ideas how I can get it to rembemr this is UK and not IE version to avoid fixing the match once per week? Thanks
