Server Version#: 1.32.6.7557
How can I get plex to share imported poster art once saved to plex?
Once you edit something on the server using Plex for Windows or Plex web, those changes should be uniform across the all your devices already. There are no extra steps to take
Some apps are a bit stubborn about reflecting changes. You may have to refresh the app, or even in some cases force stop the app and delete the cache
Thank you for your response. Does it matter what kind of library it is? The movies library poster art comes across just fine, but the ones I have created called other videos are the ones where the poster art doesn’t comes across other linked devices.
It should be working but there’s a bug
