How to ignore German - LD
Hello
plex movie scanner gives the wront movie title to the metadata handler.
i have to remove the words: GERMAN and LD nearly everytime, thene the movie is found.
is there a possibility to filter thouse words out of the movietitle?
do i need a custom moviescanner?
where can i get such a scanner?
PS: kodi recognize 99% of my movies, plex about 50%
thank you
it is probably only spam in the file’s embedded meta data
do this:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
If a movie was mismatched before, perform the Plex Dance after making the above configuration changes.
i made your changes but still the same:
Paranorman.German.DL.AC3.Dubbed.1080p-selfripped
gives the movie Title: Paranorman German DL --> nothing is found…
i searched google and found other people with the same problem: GERMAN DL, please remove the words: german, dl from the scanner
gives the movie Title: Paranorman German DL → nothing is found…
That naming is simply VERY wrong for Plex. Try “ParaNorman (2012).ext”
See: https://support.plex.tv/hc/en-us/articles/200381023-Naming-Movie-files
I do not use the separate folder for each movie that is suggested as I do not care about or want the few things it brings BUT I follow the naming exactly and the last time I had to rebuild my movie library of nearly 3000 movies Plex only missed on four. (Those four are pretty inexplicable but fixing four out of 3000 is not really a problem for me.)
I also always do as @OttoKerner suggested to totally avoid any embedded meta data.
https://support.plex.tv/hc/en-us/articles/201543057-Why-is-some-of-my-content-not-found-
You need at least to include the release year in parentheses.
