Server Version#: 1.21.0.3711
Client Version#: 5.5.1
Platform Version#: 5.1.1
I recently purchased a LG 65CX and having great fun with it. The TV doesn’t support DTS, but Plex solved the problem with 5.1ch audio transcoding. Everything works beautifully until last week, sudden when I play any video with DTS transcoding audio, the whole screen will turn into a green, red or other random color mess. The sound was audible, but the picture is constantly corrupted. When I switched the audio stream to normal AC3, the picture is normal, but the audio is completely silent. This bug drove me crazy. This is a brand-new TV with less than 1 month of use. Now all movies with DTS are unplayable!
I had to dig further with the issue. I looked at the logs but found nothing ( the log are really not for everybody). I uninstall the Plex Server and install the older versions. Nothing was fixed. Meanwhile all the videos are played just fine in my PC.
Finally I go to the “Settings” in LG’s Plex App, there in the “Advanced” there is a “Reset App” button. I hit it and it was reset, then asked me to link the account again. Once the account is relinked, Plex App works beautifully again !
Update: Now I know why it appeared to be “fixed”. When I reset the App, the settings will roll back to “Audio codecs: TrueHD
AC-3
DTS
So for some reason, when I play a video with DTS, the LG TV was able to play it with normal sound, but as soon as I uncheck the DTS setting, the problem just comes back.
I tried multiple server versions, I tried early-access and normal versions of the App, I looked at the logs… but nothing really helped.
This is quite a frustrating night. I hope someone know how to fix it and let me know. Thank you!
