I am buying a NAS(DLNA) Server (NEED HELP)
I was looking at this brand and did not see it under compatible listing but in the information it says that it runs “PLEX”
Noontec TerraMaster
Please let me know if this is good or not my price range is 100-180$ (I have some old hard drives I was going to toss in it)
Basically I will be using this for our in home network and remote network on PLEX
**Please let me know if compatible or not and how easy it would be…
Also Do these NAS servers take any SATA Hard drive?**
https://www.amazon.com/Noontec-TerraMaster-F2-220-2-41GHz-Personal-Diskless/dp/B01M4IQ506/ref=sr_1_5?ie=UTF8&qid=1479546954&sr=8-5&keywords=nas+dlna
Noontec TerraMaster
I think even if you get Plex Media Server installed on this low powered machine you are going to be very disappointed.
First, as has already been said, Plex doesn’t support the manufacturer, so getting a PMS install to work might very well take a herculean effort. One that most technophiles might not be able to do. (I wouldn’t want to try it, that’s for sure.) I know they claim it’s Plex ready on Amazon, but looking at their own website it’s not shown there. http://noontec.com.au/index.php?m=Product&v=Default&i=224
Next, once it’s installed, the low powered CPU means you aren’t likely to get much in the way of transcoding from the device. (I know, I hate transcoding, but there is always some that needs to happen, no matter how perfectly you maintain your media.) It has the J1800 CPU in it, which, sadly is WAY underpowered…
It’s about the same specs as the Asustor AS-500x series of NASes. So this means you can expect it to have about 1K passmarks. (remember, transcoding 1080p requires at least 2K passmarks for an 8Mbps stream…)
And if your budget is under $200 then your best bet is to use a desktop and add an external hard drive, IMO. Chasing performance with an under-powered NAS is going to be a nightmare. (Trust me, been down that road and it’s not pretty.)
If you put more money into the NAS itself you can get something that isn’t going to be quite so disappointing, long term: https://www.amazon.com/ASUSTOR-AS6202T-2-Bay-INTEL-Quad-Core/dp/B014MRW45U/ref=sr_1_3?ie=UTF8&qid=1479597447&sr=8-3&keywords=NAS+Asustor QNAP and Synology also have their own similar models. This one has about 1600 passmarks, so still underpowered, but much better than what you linked. With this you can do the media prep and reduce the transcoding requirements to almost nothing.
And I wouldn’t use any old drives in it at all. Only put new drives in it. Any issues with the NAS starting or reading the data and the likely issues are the old drives that have already burned through the MTBF when on your other devices.
My two cents…
I know by now alot of NAS’es out there can run Plex well but I have 5 NAS boxes and all of then are attached as simple Windows shares. I’m not using the plex software that was pre-installed on the NAS. My computer does all the work. I have no problems at all. I have had 9 people streaming from my plex without an issue.
Because of this I chose to get cheaper NAS boxes and never looked back.
So basically what I should do is just BUY a “computer” and make it a dedicated server would be my best bet
Oh hell, I wouldn’t say that. It just works for me. Other people would disagree.
NAS boxes are so dang expensive and to have a really good one(keep in mind, I said only one) could be $ 500 or more. AND then you need the buy drives…THEN you run out of space… CRAP, now what??
And a computer by itself will run out of space too. Motherboards only have so many SATA ports and PCI/PCI-E slots. After that you will have to attach some external drives to it in some way, shape, or form…
Noontec TerraMaster
What ever you do make sure you do your homework first. Plex have detailed pages on NAS requirements and pitfalls. Just google for the appropriate links. For money a couple WD External HD’s are a value option.
